5.9L Engine Club
Old 11-16-2009, 10:12 AM
95RAM360's Avatar
95RAM360
95RAM360 is offline
you'll see a difference
did you use the hughes plate? if not expect to change it again in about 50-60K
and congrats. its a big job to do. i felt proud of myself when i got done. and i ran into flukes as well.
  #242
Old 11-16-2009, 02:46 PM
gtup's Avatar
gtup
gtup is offline
It does feel good...
After everything was all said and done there was a nipple on the throttle body that I couldnt find... is there a vaccum line that goes to it...? Or is just just suppose to be capped?
  #243
Old 11-16-2009, 02:57 PM
95RAM360's Avatar
95RAM360
95RAM360 is offline
mine does have a vacuum that goes int the throttle body, it comes from the pass. side.
  #244
Old 11-17-2009, 06:56 AM
gtup's Avatar
gtup
gtup is offline
From the back of the passenger side? I cant find this line for anything, so right now I have it capped which its throwing a P1494 which could mean a vac leak. Does anybody know where this vac line goes to?
  #245
Old 11-17-2009, 07:33 AM
95RAM360's Avatar
95RAM360
95RAM360 is offline
P1494 is a Leak Detection Pump Switch or Mechanical Fault.
and mine comes from the EGR valve...i dont believe you have EGR
  #246
Old 11-17-2009, 07:47 AM
gtup's Avatar
gtup
gtup is offline
I thought all trucks have to have an EGR valve, but to come to think of it, I never saw one... After doing some reading that code could be caused by a vacuum leak, so I need to find it and see if the code goes away. I have that nipple cappped right now and the truck is running fine but need to find it.
  #247
Old 11-17-2009, 07:48 AM
gtup's Avatar
gtup
gtup is offline
Do you think if I call the dodge dealership they can tell me? lol
  #248
Old 11-17-2009, 12:10 PM
95RAM360's Avatar
95RAM360
95RAM360 is offline
i think they eliminated EGR in 99....and it all depends on your dealer...my dealer answers any question i have...bu thats becuase i buy alot from them and they know me by name.
  #249
Old 11-17-2009, 06:57 PM
DirtDiver's Avatar
DirtDiver
DirtDiver is offline
Nim81..
Thanks for the advice. I forgot i did add a 180% T stat..so I will look at the super chips.I have to ask, what is the plenum? I see a lot of guys are replacing it for gains in HP.
  #250
Old 11-17-2009, 07:11 PM
95RAM360's Avatar
95RAM360
95RAM360 is offline
there is a plate mounted to the bottom of the manifold. the gasket its between the plate and manifold. the poor design of aluminum to steel makes it expand differently at tempretures, hense enough pressure to blow through a pocket when expanded, in end blowing the plenum gasket which aloows oil to leak into the manifold, which will foul plugs, kill 02 sensors, clog the cat, maake it runpoorly, and get very poor gas milage
hopefully that made you understand
Quick Reply: 5.9L Engine Club
