rear end gears
what is the big difference between rearend gears im mean ive heard of 2.55 all the way up to 4.56 and i kno that means the tire spins once for that many times the driveshift spins but wuts the big difference
Ever ride a bicycle with more than one gear?
Different gears allow the engine to operate at different speeds to take advantage of characteristics of horsepower, economy, torque curve. Some gears are better for mileage, some better for performance.
My RAM 2500 3.9L V6 automatic has 3.50 gears in the rear, with that ratio, I can actually tow something with a little V6
and it moves out quite smartly. Given the lack of torque this motor makes, a higher number = good.
If the 4500lb van had Magnum R/T gears in the rear (2.82 I think) it wouldn't get out of it's own way, never mind tow anything.
If the Magum R/T had the van gears in it (3.50) it would accelerate like absolute gangbusters, and probably STILL make it to 130.
Mike
Mike
5.9 360 has a 3.55-1 ratio sp is that better for fuel economy of puttin power to the ground or wut
Trending Topics
the way mike makes it sound is that the higger tha ration the lower the top end speed is that true
yea it seems a bit econmy mopartodd ~20 miles a gallon hwy
but it does go pretty good
