No Electric, Battery OK
Old Oct 26, 2004 | 12:05 PM
hoops222222's Avatar
hoops222222
Default RE: No Electric, Battery OK
Thanks mopartodd
I appreciate your time and effort.
hoops
Old Oct 26, 2004 | 12:49 PM
moparturd's Avatar
moparturd
How did you check your fuses? With an multi meter? Checking for voltage, or ohms?
moparturd's Avatar
moparturd
Do you have a fax#?
Old Oct 26, 2004 | 12:54 PM
hoops222222
I check the fuses by pulling each one out and seeing if it was broken or not.
I have a fax, but its the company's and there's about 50 people that use it.
If there only a few pages, it should be OK.
973 565 7651
Thanks again
hoops
Old Oct 26, 2004 | 01:17 PM
moparturd's Avatar
moparturd
To do this properly, you need to have a multi meter to check the fuses. Visually inspecting them does not always work. I have a ray of hope now that I know you didn't use the meter. I'm going to fax you, hoops, a page from the shop manual that breaks down the fuses in the IPM in the engine bay. From there we'll need to pull the fuses and ohm them out, check for continuity. If they check out then you'll have to look at checking voltage to the module.
Check your fax. It just went through.
Old Oct 26, 2004 | 01:29 PM
hoops222222
I just received the fax...
I do have a multi meter.
To ck continuity, do I just place the lead from the multimeter to both side of where the fuse came out from? And do I look for volts, ohm, or amps?
Old Oct 26, 2004 | 01:35 PM
moparturd's Avatar
moparturd
To check continuity, pull the fuse out of the holder and put 1 lead to either side of the fuse, then the other to the other lead. It's important to remove the fuse before doing this.
Old Oct 26, 2004 | 01:38 PM
hoops222222
I see
thanks
lets see what happens
Old Oct 26, 2004 | 01:40 PM
moparturd's Avatar
moparturd
Good luck man. I'll check back to see how it's going.
Old Oct 30, 2004 | 06:02 AM
LilSparkPlug's Avatar
LilSparkPlug
Same thing happened to my 01 Stratus R/T. One morning....bam everything GONE. And i didn't install anything. Had it towed to the dealer Daimler Chrysler had to come down and fix it....I can't remember what it was though, did have to do with fuses though, one that kept blowing for no reason. And my PCM was fried....again for no reason. [>:]
Good luck
MoparTodd your the man
