Keep hearing this clicking noise
Old Sep 8, 2007 | 01:21 PM
04DodgeRam1500's Avatar
04DodgeRam1500
Default Keep hearing this clicking noise
keep hearing this clicking noise and it raspy sound. It gets louder when I accerelate. truck has a 4.7 liter V8 with 63,400 miles on it. Any ideas?
Old Sep 8, 2007 | 11:08 PM
dishdude2k's Avatar
dishdude2k
Default RE: Keep hearing this clicking noise
sounds like the fan hitting the shroud maybe?
Old Sep 9, 2007 | 08:48 AM
United1's Avatar
United1
Could it be the notorious broken exhaust manifold stud issue with the 4.7's? Does the clicking ever go away when it warms up?
Old Sep 9, 2007 | 12:36 PM
SrtHemi's Avatar
SrtHemi
Could be a lifter?...
Old Sep 9, 2007 | 12:40 PM
04DodgeRam1500
ORIGINAL: United1
No, acutallly you don't hear until after it beens running for about 5-10 mins. I took it by a shop and they said it sounded like a fan clutch bearings are going out. But the fan is spins off the water pump and I took one of those stethlo scopes and listen to it and it wasnt anything unsualy but truck has two cooling fans and the other I have not listen to yet but could that be it.? Also are they suppose to have two fans?
Old Sep 9, 2007 | 05:12 PM
04DodgeRam1500
ORIGINAL: dishdude2k
How could I tell if that is what the problem is?
Old Sep 9, 2007 | 06:27 PM
SrtHemi's Avatar
SrtHemi
ORIGINAL: 04DodgeRam1500
Look for pieces missing out of the shroud/ or the fan.
Old Sep 19, 2007 | 09:52 AM
dansimonds's Avatar
dansimonds
Is your truck a 4x4? Mine is and I had the same thing.It was the u-joints on the front 4x4.Also.if you have hubcaps,check that one isn`t loose.
