24 valve coolant leak
Old Sep 29, 2007 | 10:03 PM
cowboy1karate's Avatar
cowboy1karate
Default 24 valve coolant leak
I have a '99 Ram 2500 24 valve with 85K miles, and I noticed coolant leaking from what appears to be the head gasket. The leak is directly under the thermostat housing.Does anyone know if this is a common problem and if sohow to repair it?
Old Oct 4, 2007 | 08:31 PM
dodgeTEXAS's Avatar
dodgeTEXAS
Default RE: 24 valve coolant leak
i havent had too many 5.9l diesels leak from the headgasket. are you certain its from under the tstat housing. i usually have water pumps leak more than anything.
