Body control module reset
Old 11-09-2004 | 06:13 PM
josh4rim's Avatar
josh4rim
Default Body control module reset
The Body Control module went out causing all kinds of problems on my 99 stratus. I took it in and they replaced it with a used one, well then my odometer read the other cars odometer reading of 147k and my car only had 43k when I had taken it in. The co. that put it forgot to write down the milage, but to set it back to an app would be illegal. But since the body control module was going in and out the milage was not accurate when we took it in they said it would be illegal for them to set it back, they also didn't know how to. I called the state trooper office they said there is nothing I could do. Is there a way to reset the odometer because this really dropped the value of my car which I may sell soon. Thanks.
Old 11-09-2004 | 11:29 PM
JCswm's Avatar
JCswm
Default RE: Body control module reset
The current milage is s stored in the PCM also...
A dealership will install a new BCM with the proper milage "Burned in"
Old 11-10-2004 | 04:50 AM
josh4rim's Avatar
josh4rim
So If I take it to the dealer they will know the correct milage by the PCM and be able to reset it? Thanks for the reply.
Old 11-11-2004 | 01:13 AM
JCswm's Avatar
JCswm
NO.... once Burned in it cannot be changed!!!!
They can sell you a new BCM with the correct milage
Old 11-17-2004 | 04:40 PM
josh4rim's Avatar
josh4rim
But the dealer will know the correct milage?
Quick Reply: Body control module reset
