I broke the oil pan...
Old Nov 10, 2007 | 02:06 PM
Veclord's Avatar
Veclord
Default I broke the oil pan...
I was going down the road yesterday and "accidently" ran over a spiked piece of asphalt in the road were the city was doing some construction. I was in the left hand lane and swerved toward the curb to keep from getting a flat tire. The piece of debris wasn't very tall or wide, but enough to gouge a hole in that pan next to the left front steer tire on the driver's side. I pulled over and looked under the hood to find lots of red fluid leaking out (which I guess was the transmission fluid).
Someone please help as this is my only ride to work and back. My Dad grew up around cars and knows lots more than I do but we don't know if it'd be fixed just by replacing the pan, repair costs, or how much damage might have been done to the transmission.
EDIT: I forgot to add what car I had. It's a 1990 Dodge Spirit V6.
Old Nov 10, 2007 | 10:25 PM
dishdude2k's Avatar
dishdude2k
Default RE: I broke the oil pan...
a piece of asphalt broke the pan? that sounds a little far fetched.. does the car still drive? ya need to find out EXACTLY where the fluid is coming from.. might wanna check and make sure you didnt pull a half shaft out of its seating.. with the jerk of the wheel.. its possible..
Old Nov 10, 2007 | 11:25 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
You need to drop the tranny pan and make sure the damage was only skin deep. If so, get a new tranny pan, 4 qts of ATF+4 and some Permatex Right Stuff sealant. Start by adding2.5 quarts,then check and add as necessary. Once it's warm and reads full, you're on your way.
Old Nov 11, 2007 | 01:00 PM
Veclord's Avatar
Veclord
Default RE: I broke the oil pan!
ORIGINAL: dishdude2k
I know how rediculous it sounds but I swear it's true! I knew it was coming out of the pan since I checked right away and could see the gash plus the fluid basically pouring from that area.
It might not have been asphalt. I'll be honest; I don't know WHAT the hell it was! Just sort of like a pointed pyramid black chunk of something.
Old Nov 13, 2007 | 05:34 PM
stonentwolf's Avatar
stonentwolf
I just damaged my tranny pan. I called the dealer and they want $46 for one. That wasn't too bad in my opinion.
Old Nov 13, 2007 | 07:00 PM
dishdude2k's Avatar
dishdude2k
yea.. not too bad for a preformed hunk of steel... im sure it was about 30 bucks cheaper at the boneyard.. but hell.. why save any money on it
Old Nov 13, 2007 | 10:52 PM
stonentwolf
I have two jobs and get a simultaneous day off from both about once every two months.
A few months back I spent an entire saturday calling every junk yard within 30 miles looking for a left turn signal assembly for my mom's durango and didn't find a single one and ended up having to buy it from the dealer anyway.
If I have to, I can ask my girlfriend to go to the dealer for me and get the part, but I think sending her to the junk yard with a tool box is a little bit to ask.
Old Nov 13, 2007 | 11:03 PM
teva_feet's Avatar
teva_feet
I want pics of the gash and gore!
ORIGINAL: stonentwolf
same request [8D]
Old Nov 14, 2007 | 04:13 PM
moe7404's Avatar
moe7404
moe in wichita ks. i would have strightened the pan with a hammer. then weld the hole shut. check for leaks with water, dump out the water and put the pan back on truck. not a big deal.
