Coolant in Engine Oil???
Old Nov 20, 2007 | 11:14 PM
Sick_340's Avatar
Sick_340
Default Coolant in Engine Oil???
Hoping you Mopar guys (or anybody) can help with my problem. I have a 1969 340 small block dodge motor losing coolant into the engine oil. It seems to be a slow leak as it takes a few weeks to notice water in the oil. I have replaced all seals and gaskets in the top half of the motor, and used thread sealer where head and water pump bolts go through water jacket. I tightened all bolts down to spec, and used rtv sealer where needed. I thought it was fixed but this weekend I checked the oil and appears to again have water in it. Could a leaking timing cover gasket be letting coolant drain into the oil pan or could the aluminum cover itself be cracked on the inside and letting coolant into the timing chain area and then down into the oil pan. I have read about the last part being the culprit in a similar situation. I hope you guys can help as I am getting very angry about not getting to the root of this problem.
Old Nov 21, 2007 | 11:47 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Default RE: Coolant in Engine Oil???
The most common culprit is the intake gasket or timing cover gasket. Intake gasket killed the 318 in my '51 pick-up (which gave me an excuse to build a wicked 360 for it [sm=crossbonesgif.gif])
Old Dec 4, 2007 | 07:19 PM
Sick_340's Avatar
Sick_340
Surly with all these Dodge people someone else might have an answer for me ......
Old Jan 15, 2008 | 11:10 AM
clops79's Avatar
clops79
cracked head and did you relace head gaskeits
Old Jan 15, 2008 | 09:27 PM
Sick_340's Avatar
Sick_340
Changed the gaskets, didn't find milky residue in heads. I hope it is a leak in the timing cover area.
Old Jan 15, 2008 | 11:05 PM
moe7404's Avatar
moe7404
moe in wichita ks
i do NOT like rtv sealers. i like permatex #2. rtv acts like a luberacant and lets things move around. and #2 works everywhere, even threads. in alunamiun, and spark plugs use anti-sieze compound, and be careful of tourq,spec. pardon my spelling
Old Jan 16, 2008 | 08:54 PM
Sick_340's Avatar
Sick_340
Well I say rtv, but it was actually permetex ........
Old Jan 22, 2008 | 11:28 PM
moe7404's Avatar
moe7404
moe in wichita ks
permetex is a brand name that includs lots of products. years ago before they had rtv theyONLY had #2#1and i think #3 i have NEVER had #2 fail me
Old Jan 23, 2008 | 10:41 AM
Sticky Sam's Avatar
Sticky Sam
I am guessing cracked head. Run engine warm, if water is coming out of your exhuast pipe, possible cracked head or block. Check spargplugs for rust spots/water, note which cylinders are different colour. I usecardboard with a rough drawing off engine layout and an arrow pointing to front of engine. Bung 6 or 8 etc holes in cardboardwhere cylinders would be tomatch any duff plugs to cylinder.
Old Jan 30, 2008 | 01:11 AM
StevenMoffettKY's Avatar
StevenMoffettKY
ORIGINAL: Sticky Sam
I am guessing cracked head. Run engine warm, if water is coming out of your exhuast pipe, possible cracked head or block. Check spargplugs for rust spots/water, note which cylinders are different colour. I use cardboard with a rough drawing off engine layout and an arrow pointing to front of engine. Bung 6 or 8 etc holes in cardboard where cylinders would be to match any duff plugs to cylinder.
Uh oh. I noticed the other morning when I was letting my truck warm up in the morning that I had some dripping from my exhaust pipes... should I be alarmed?
