check engine light after exhaust change
Old Dec 10, 2004 | 10:49 AM
vlsun's Avatar
vlsun
Default check engine light after exhaust change
i recently changed my exhaust system and just today i got the check engine light. what the hell? the truck is running great, no problems thus far... (knock on wood)
Old Dec 10, 2004 | 10:53 AM
Snafu's Avatar
Snafu
Default RE: check engine light after exhaust change
What did you change? A lot of times an exhaust change screws with the oxygen sensor(s). Our trucks typically have one before and one after the cat. It looks for a difference between the two readings to be in a set range. You put a high-flow exhaust on or junk the cat, you often will put the difference out of the range and trigger a code.
Old Dec 10, 2004 | 10:55 AM
datacop's Avatar
datacop
when you say that you changed your exaust system.. did you change mufflers, cat, headers and everything?
{edit} Curses.. Snafu beat me to the punch.. blasted co-workers coming into my cube and interupting my browsing internet forums time {/edit}
Old Dec 10, 2004 | 02:22 PM
vlsun's Avatar
vlsun
just the muffler and pipes after the cat.
Old Dec 10, 2004 | 03:44 PM
Snafu's Avatar
Snafu
The rear oxygen sensor might have gotten messed up. Were the pipes and muffler stock replacements or high-flow?
Old Dec 11, 2004 | 03:14 AM
vlsun's Avatar
vlsun
it was the jba system, so high flow. what should i do?
Old Dec 11, 2004 | 09:47 AM
SnipeRT's Avatar
SnipeRT
ORIGINAL: vlsun
Have you checked the trouble code yet? That would normally give you a pretty good idea of what is causing the MIL to illuminate. If you don't have the ability to check your codes yourself, I believe Autozone still offers free code scans. Be sure to write down the "P-code" (P0XXX or P1XXX), and post it here.
Old Dec 12, 2004 | 12:36 AM
Drew's Avatar
Drew
I'm going with snafu on this one. . .I changed out the exhaust on my taco and had the same thing. . .drove it around for a bit and it went away. it's prolly just your O2 sensor.
if it doesnt clear out after a while of driveing the it could be your O2 sensor did go out
Old Dec 13, 2004 | 01:52 AM
casper's Avatar
casper
Try reseting the PCM by disconnecting the negative battery terminal for 30-60 mins. That will clear all the trouble codes, if it comes back find out what code it is and post it here and we will help you.
Old Dec 13, 2004 | 03:14 AM
SnipeRT's Avatar
SnipeRT
ORIGINAL: casper
Try 30-60 seconds next time... It's alot quicker.
