Need Help ASAP
Old Dec 15, 2004 | 03:52 AM
1997neon's Avatar
1997neon
Default Need Help ASAP
i just replace the head gasket on a 97 neon sohc and not the rear of the engine is leaking oil i accedently adde about a quart of extra oil would this make it leak out the extra oil it is just running out at a steady rate it looks like it is fron the passenger sie rear of the oil pan or block there is a crack in the timing belt cover but that does not have any oil right? the oilf filter is on tight i never took the oil pan off so it should not be the oil pan gasket any body have any thought on what it might be thanks
Old Dec 16, 2004 | 10:15 PM
casper's Avatar
casper
Default RE: Need Help ASAP
Without pictures or more information, I would say that you didn't tighten the head bolts down correctlly or did something when you changed the gasket, if it was not doing it before.
