engine no start again
Old Dec 24, 2004 | 09:06 PM
kevmic28's Avatar
kevmic28
Default engine no start again
I got up this morning for work and my car would not start. I have no fuel pressure in the fuel rail. And I cant hear the fuel pump prime when I first turn the key. The car has run fine until this morning. I visually check the fuel pump fuse and switch the relays thinking that was it but no luck. Anybody have any ideas before I pull the tank and change the fuel pump????
Old Dec 24, 2004 | 09:31 PM
Yellow Runner's Avatar
Yellow Runner
Default RE: engine no start again
i dont to much and not tryn to be a smarta** but would a dead batterie have anything to do with that? wouldnt think it would but jsut asking.
Old Dec 24, 2004 | 09:35 PM
kevmic28's Avatar
kevmic28
I have a good battery, the car turns over, its just not getting fuel. I was wondering if there is a fuel cutoff switch, I know ford has them, but I dont know about Dodge. I thought they were standard but maybe not.
Old Dec 24, 2004 | 09:56 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
hmm..not that i know of...check for a fuel pump fuse..my stratus has one..itll crank forever and not start
Old Dec 24, 2004 | 10:04 PM
kevmic28's Avatar
kevmic28
I checked the fuse, but maybe I need to pull it and switch it for another.
Old Dec 24, 2004 | 11:08 PM
kevmic28's Avatar
kevmic28
Ok I checked the fuse and swapped it for another and still no start. Still no power to the pump. Can a fuel pump just quit without warning?
Old Dec 25, 2004 | 11:20 PM
kevmic28's Avatar
kevmic28
I checked today and I have power to the fuse and to the relay. I was thinking I was smelling gas fumes the other day before it died. I thought it just because I was getting a cel code for the gas cap. I looked under the car at the gas tank and it looks like gas has been leaking from around the fuel pump area down the side of the tank. So I am fairly certain that it is the fuel pump now. Now I just need to come up with the 185 dollars for the pump. i guess the car will sit till the 15th payday.
Old Dec 26, 2004 | 12:55 AM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
is that price a mopar part or aftermarket, labor or no?
Old Dec 26, 2004 | 11:04 AM
kevmic28's Avatar
kevmic28
Its aftermarket price from autozone, no labor. My labor. I do have a question though.. Do I have to drop the tank or can I pull the fuel pump from the side. I can see the pump its angled on the side of the tank.
Old Dec 27, 2004 | 12:11 PM
kevmic28's Avatar
kevmic28
I found one at a salvage yard for 50 bucks. it has 4000 miles on it. I am going to try it and save a little money for now. But I was just thinking about changing the fuel filter first though. I was wondering if the filter was clogged that it would keep the fuel pump from working???
