Crossed My Battery Wires!
Old Mar 20, 2008 | 01:29 PM
uqdah2000's Avatar
uqdah2000
Default Crossed My Battery Wires!
I need help bad! My 2000 Neon would not start. After receiving a jump start I was OK. Upon inspecting the battery I decided to buy a new one. Went to Sears, bought a new Die Hard. Instead of selling me a type 26R they sold me a type 26. The difference is the position of the posts. When I attempted to connect the new battery the wires would not reach the posts. Foolishly in the dark of night I turned the battery around and did not notice that by doing this I was about to connect the wires to the wrong posts! When I made contact with the wrong posts I got a spark followed by flame and smoke. Quickly I disconnected, exchanged battery and connected properly. The car did start OK, but the next day the battery indicater light appeared on the dash. My neighbor tells me to start the car & disconnect the negative battery wire. The engine stopped. He says the alternator is bad. I buy a new alternator, neighbor installs it and guess what, same problem. I noticed that the fuse in the radio blew, but could not find any more blown fuses. What do you think I fried?
Old Mar 20, 2008 | 01:39 PM
PappiDread6's Avatar
PappiDread6
Default RE: Crossed My Battery Wires!
OOOOOOOH!![:@]I think you might have fried your PCM/ECM![:@]
Old Mar 20, 2008 | 02:03 PM
bad venge's Avatar
bad venge
Section Moderator
check for fusible link wirimg especiallyu in the alternator /main fuse box area , also look for burnt wiring as you don't say where the flames come from ... might have burnt out the voltage regulator
Old Mar 20, 2008 | 09:07 PM
b00rad's Avatar
b00rad
yeah check ur fuse box first, if not there check starter, may have fryed that, by doing that u deffinently fryed something, there should be a fuse that will pop if that happens, so that it wont kill ur PCM, so if ur fuse is fine, then take it to a mechanic to run diag to see what u fryed.
Old Mar 20, 2008 | 09:30 PM
uqdah2000's Avatar
uqdah2000
Thanks for all of your input. Tomorrow i'll do a thorough check. I did check the fuses inside the car and the ones under the hood. They were fine, although I don't know how to tell if the relays under the hood are OK by sight. All electrical components seem to work though.
Old Mar 26, 2008 | 08:38 AM
uqdah2000's Avatar
uqdah2000
It was a fusible link in the power wire to the alternator. Thanks everyone! Now I'm good to go.
