Smell of coolant
Old Jun 5, 2008 | 07:01 PM
Boothe99's Avatar
Boothe99
Default Smell of coolant
After leaving my truck sit all night, i have been recently noticing that I smell coolant when i start it. In addition, since this has started, my oil pressure gauge has been movie very fast. This is not normal for how it has been. If I press the gas, It increases rapidly. When I release it, it drops down. I have checked the oil, i recently changed it, and it is full. My coolant slowly goes away. But I have yet to see any leaks from either. If anyone can help, let me know.
Old Jun 6, 2008 | 01:31 AM
tom01973's Avatar
tom01973
Default RE: Smell of coolant
check the watr pump for a leak also check the intake manifold gasket for leakage.
Old Jun 6, 2008 | 03:58 AM
Boothe99's Avatar
Boothe99
I have not seen anything leaking under. I cant find anything leaking at all. In the morning when I smell it, my exaust pipe is "smoking." Could that be the head gasket? Just its leaking on the inside?
Old Jun 6, 2008 | 07:26 AM
cletus3094's Avatar
cletus3094
Depending on the year, My last Ram was an 03. therewas a recall on the lower radiator hoses and power steering hoses. Even though they replaced them I still had the issue. The only other thing I noticed was when I changed the oil, there was condensation on the bottom of the fill cap but the engine never gave me a problem even after 90k miles.
Old Jun 6, 2008 | 08:59 AM
timsalas's Avatar
timsalas
Is the smell inside or outside? Any white smoke?
Old Jun 6, 2008 | 03:26 PM
Boothe99's Avatar
Boothe99
Mines at 90K now, its a 2001 Ram 2500.
Old Jun 6, 2008 | 06:30 PM
Boothe99's Avatar
Boothe99
The smell is on the outside. Sometimes inside. Yes,. there is white smoke from the exuast
Old Jun 7, 2008 | 01:15 AM
tom01973's Avatar
tom01973
did you check the intake gasket like i suggested?they are known to leak and you may not be able to see it.
