Electrical
Old Feb 24, 2005 | 04:46 PM
damndodge's Avatar
damndodge
Default Electrical
I have a 1987 dodge ramvan 250, I have bought new battery, alternator tested great, and voltage reg checked. Still not holding a charge. While driving it's fine, as soon as I turn it off it will not restart! Also checked fusablelinks. Any sugestions?? Thanks
Old Feb 24, 2005 | 04:56 PM
moparturd's Avatar
moparturd
Default RE: Electrical
Do you have a draw on the battery when it's not running? Is the problem that it won't start, or that there's no power to start it?
Old Feb 24, 2005 | 04:58 PM
damndodge's Avatar
damndodge
There is no juice to start. Just a clicking sound, not even turning over.
Old Feb 24, 2005 | 04:59 PM
moparturd's Avatar
moparturd
Starter relay would be my guess.
Old Feb 24, 2005 | 05:00 PM
damndodge's Avatar
damndodge
Starter relay would drain the battery dead tho?
Old Feb 24, 2005 | 05:03 PM
damndodge's Avatar
damndodge
I have to hook the battery charger up to it just to get it to start, then when I shut it off, it wont restart without the charger.
Old Feb 24, 2005 | 05:05 PM
moparturd's Avatar
moparturd
No it would not. My mistake. There has to be some draw when it's off if it's pulling the battery down overnight. It would have to be a major draw too. Not something small like a light or whatever.
Old Feb 24, 2005 | 05:22 PM
damndodge's Avatar
damndodge
Well thats what I thought too at first, but it's when I get it started, and let it run for awhile even drive it, then pull back into driveway turn it off, and try to restart, then it wont start again. I have to put it back on charger.
Old Feb 25, 2005 | 04:03 PM
damndodge's Avatar
damndodge
So I took the volt reg completely off, and I have good power going to the alternator and the battery. It starts everytime without draining the battery. I changed the volt reg, and the same thing keeps happening. The battery wont hold a charge. Could there be a short in the wiring that goes from the volt reg to the battery? If so how do you find out??
Old Feb 25, 2005 | 04:35 PM
Snafu's Avatar
Snafu
I had that exact thing happen on a tow truck I used to own. The wire from the voltage regulator to the battery would go bad once in a while. I just replaced it with a heavy wire and it was good. You may have an issue between the alternator and voltage regulator too. That's what it sounds like from my experience with this.
