02 sensor question
Old Mar 15, 2005 | 12:47 AM
ss396chevelless's Avatar
ss396chevelless
Default 02 sensor question
I have a 99 Dodge Ram 4x4 with a 5.2/5 speed and have been having trouble with engine perfoamance whenever the O2 sensors are giving me an output. I bought a new precat sensor and put it in but it didnt help. My question is: Is the post cat sensor the same sensor? because obvoiusly the one I took out was ok, so I want to try putting that in the other one. Or will they not hook up. Just trying to find out before I get under there because I dont have a garage to work in and it is winter here!
I also have an actron CP9145 if anybody has any suggestions of what Data outputs might help my problem search
Thanks for any Help
Josh Sauls
Old Mar 16, 2005 | 10:56 PM
bagged318's Avatar
bagged318
Default RE: 02 sensor question
i was having engine probs with my 99 dakota 5.2 5-speed. rough idle and just crappy performance. i bought an o2 eliminator from fastman.com. i have a brand new pre-cat o2 and replaced the after-cat with an eliminator. runs like a dream. should work for you. but, at least call this guy, he is pretty helpful. you can not buy from the website but, like i said, RUNS LIKE A DREAM. best $75 i ever spent on the truck.
Old Mar 16, 2005 | 11:25 PM
Leonard's Avatar
Leonard
Default re:Is the post cat sensor the same sensor
I was told that the only difference between O2 Sensors on a particular vehicle was the length of the wire harness.
Mine appear to be that way but I would imagine Snafu, GM sucks, or Mopar Todd will correct me if I heard wrong.
Old Mar 17, 2005 | 12:35 AM
Drew's Avatar
Drew
Default RE: re:Is the post cat sensor the same sensor
read up by clicking me
might give you a little insight
Old Mar 18, 2005 | 05:32 AM
bagged318's Avatar
bagged318
forgot to answer your question: post-cat and pre-cat are the same sensor. same part number and everything. if memory serves right: $124.99 each. or, $75 for the eliminator.
Old Mar 20, 2005 | 07:59 PM
ss396chevelless
It ended up being the post cat sensor, Once I got under there to get a good look at it i saw some tiny breaks in the wire casings and the wires inside were green. Went and picked up a new sensor (they were the same but the adapter is a little different) which sucks cuz I had a new pre cat here. Anyhow, I went to put the new one in and it wouldnt FIT! the hole in the Pipe wasnt big enough (the old sensor tip was smaller) So i tried to make it bigger with a file, got the new sensor started in and then it popped out screwin the threads up.... Pulled the whole pipe out of the truck so I had enough room to work on it (there pipes are true custom duals) Well, I filed the hole a little better and ran a tap down the Bun, then a die over the sensor to clean up the thread that popped and it screwed right in. Reassembled the exhaust.. replaced a broken shock then took it for a test drive. I drove it about 5 miles to my buddies after clearing the computer codes, then back home and never had a problem with it. Check Engine light is still off! But.. Ill give it a week before I claim it is definatly fixed LOL
Thanks for the help guys
Old Mar 20, 2005 | 08:01 PM
ss396chevelless
Oh, by the was, I put a Bosch sensor in it, It was $75
