View Poll Results: A poll
TRUE
81.82%
FALSE
18.18%
Voters: 22. You may not vote on this poll
I use synthetic oil in my vehicle
Old Mar 7, 2004 | 01:49 AM
  #21
dodgemech's Avatar
dodgemech
Default RE: I use synthetic oil in my vehicle
Castrol Syntec,"fully synthetic" is NOT really full synthetic. Look into the european standards. Their standards of testing are much more brutal. Castrol syntec is a full synthetic additive package but is still based on crude base. Full synthetics are have no crude base whatsoever.
Old Mar 7, 2004 | 02:26 AM
  #22
dustyloins's Avatar
dustyloins
Hall of Fame Member
Please give me a reference to your claims. And let's get ourselves a good lawyer at the same time to sue Castrol for deceptive advertising. I want to retire (again) at age 52!
BTW, the last time I looked, my driver's side exhaust tip was laying about 1" lower than the other exhaust tip and the Dodge dealer said there was nothing he could do to fix it due to the "rubber pads"...ideas/comments would be appreciated![sm=smiley4.gif]
Old Mar 7, 2004 | 05:19 AM
  #23
dodgemech's Avatar
dodgemech
castrol is not false advertising, according to U.S. regulations only the additive package needs be fully synthetic to be advertised as synthetic oil. Not sure what "rubber pads" they might be refering to, I'd look into lowering or raising one of the rear hangers. It can always be"adjusted" to fit.
Old Mar 7, 2004 | 02:00 PM
  #24
sgbofav's Avatar
sgbofav
ORIGINAL: dustyloins
Bill, I'm not questioning the quality of Amsoil in the least....I'm putting it in MY vehicle at the next oil change. But the chart posted on the website recommends longer intervals between oil changes than the jug of oil itself does...is that an administrative oversight?
Also, in the fine print at the bottom of the chart, after note #11, it says "Notice: More frequent service may be required under severe service operating conditions." Any mechanic worth his/her salt can tell you 90% of the cars in the USA fall under the "severe service" catagory. The SRT-4 owner's manual mentions this as well and my service advisor told me to go by the "severe service" schedule outlined in the owner's manual.
I guess the bottom line is I'm not going to extend the oil change intervals if I'm running Mobil 1, Amsoil, Red Line, Royal Purple, or Castrol SYNTEC. Gotta go by what the people who built the car say, at least for the next 7 yrs/70,000 miles...And Amsoil is a great product...I buy it, I use it, and I highly recommend it!!![sm=smiley20.gif][sm=smiley4.gif][sm=smiley1.gif][sm=smiley2.gif][sm=smiley17.gif]
This is exactly why I recommended you have one oil analysis done to be 100% sure as to the condition fo your oil. If you do the analysis, the lab can determine how much longer your oil can last.
If you had an engine problem and you brought your car in for warranty work, with an oil analysis result (proving your oil was still good even though you doubled their recommended oil change interval), Dodge would not have any grounds to void your warranty. I'm not trying to get you to go against your warranty, I'm trying to save you money on your oil changes.
I'm going to email Amsoil's tech service about the 10w-30 bottle recommendation and their chart being different.
Here is why I mentioned the oil analysis. Amsoil makes a 15w-40 Diesel oil that they (Amsoil) warranties for six months or double the normal interval (about 15,000 miles). Several diesel owners have decided to try oil analysis and they found out that their oil actually lasted 45 to 50,000 miles in their engines. Granted at this point the oil is no longer under warranty from Amsoil. It still worked and they determined this via oil analysis exclusively.
Here is an example of one diesel truck that ran 409,000 miles without an oil change. The oil was no longer under warranty but, it was still doing it's job. http://www.amsoil.com/testimonials/409000.htm
Here are some examples of turbocharged cars using Amsoil :
This is a Turbocharged Subaru WRX that saw regular driving plus one hour of hard racing. Read the entire thread to understand what they are talking about. Hard shifting and hard accleration causes "shock loading" on the bearings which increases the bearing wear. The readings are in parts per million so don't panic when you see the numbers http://theoildrop.server101.com/cgi/...c;f=3;t=000559
http://theoildrop.server101.com/cgi/...c;f=3;t=001178
I can't find any SRT-4 UOAs (Used Oil Analysis results) to compare.
Bill,
Old Mar 7, 2004 | 02:09 PM
  #25
sgbofav's Avatar
sgbofav
For those that don't know why some members are debating Castrol Syntec being 100% synthetic or not, here is the story:
first published in Nov., 2000 issue of Car and Driver by Patrick Bedard)
Now that the meaning if "is" has gotten so slippery you need to grab it with both hands, we'd better keep an eye on longer words, too.
One's already got so squirmy on us- "synthetic," as in synthetic motor oil.
Most guys know two things about synthetic oils. First, the price is three to four times that of conventional oils. Second, they're not real oil, not made from crude.
News flash: Scratch that second part. Now motor oils derived from crude may be labeled "synthetic." But they still cost over four bucks a quart.
Bait and switch? That's the obvious conclusion. Except in this case the advertising ethics people have given their approval.
Here's what happened, according to a detailed account published in the trade magazine Lubricants World. Late in 1997, Castrol changed the formula of its Syntec "full synthetic motor oil", eliminating the polyalphaolefin (PAO) base stock (that's the "synthetic" part, which makes up about 70% by volume of what's in the bottle) and replacing it with a "hydroisomerized" petroleum base stock.
Mobil Oil Corporation, maker of Mobil 1, "Worlds Leading Synthetic Motor Oil," said no fair and took its complaint to the National Advertising Division (NAD) of the Council of Better Business Bureaus. NAD often arbitrates between feuding advertisers on their conflicting claims.
The notion behind synthetic motor oils as we've known them is an elegant one. Instead of relying on the cocktail of hydrocarbons contained in crude oil, why not go into the laboratory and build the perfect base stock from scratch, molecule by molecule, and builds it till it gets 10-carbon molecules, then combines three of those to form PAO. The result is a fluid more stable than the usual base oils derived from crude. It keeps flowing at low temperatures. It's more resistant to boiling off, and more resistant to oxidation, which causes thickening with prolonged exposure to high temperatures.
Still, there's more than one road to the point B of improved stability. Petroleum refiners in recent years have learned how to break apart certain undesirable molecules - wax, for example, which causes thickening of oil at low temperatures- and transform them by chemical reaction into helpful molecules. These new hydroisomerized base oils, in the view of some industry participants provided properties similar to PAO's but only cost half as much," Lubricants World reported.
The argument before NAD tiptoed around the obvious- does the consumer get four bucks' worth of value from each quart of synthetic oil?- and plunged straight into deep semantics. Mobil's experts said "synthetic" traditionally meant big molecules built up from small ones. Castrol's side held out for a looser description, defining "synthetic" as "the product of an intended chemical reaction."
What do unbiased sources say? It turns out that the Society of Automotive Engineers (SAE) and the American Petroleum Institute (API) both have technical standards covering motor oils, and both of these organizations in the '90's backed away from their old definitions of "synthetic," leaving lots of room for new interpretations.
In the end, NAD decided that the evidence constitutes a reasonable basis for the claim that Castrol Syntec, as currently formulated, is a synthetic motor oil, said Lubricants World.
The obvious question now: Has the term "synthetic motor oil" been opened up to the point that it no longer means anything? Maybe. But here's a better question: Did synthetic ever mean what we thought it meant?
"Great oil" is what most guys think it means. "At that price, it's gotta be great stuff!"
Okay, but how great? Your cars manual tells what motor oil you should use, and with few exceptions, that description will consist of only two specifications. One is for viscosity, such as 10W-30; and the other is for the API service grade, SJ being the current one for gasoline passenger cars.
The buck-a-quart multi-grades meet these standards, as do the synthetics.
The synthetics, on the back label, claim compliance with more standards, but even if you know what they mean, they seem beside the point for U.S. passenger cars. For example, should you care about diesels if you drive a gasoline burner? API service CF is the oldest of the current specs for light-duty diesels; some synthetics list that one. Synthetics may also list ACEA A1 and B1, which are European specs roughly equivelant to API gasoline and diesel specs. The Europeans grad their oils by level of performance, so that A2 and A3 are tougher specs than A1. Same for diesels. Usually the date of the spec is omitted, but A1-98 is newer than A1-96.
Completely absent is the one performance claim that would have some real meaning for all of us- some indication of longer oil life. (except for AMSOIL which clearly states 25,000 miles/1-year or 35,000 miles/1-year for their Severe Service 0W-30 synthetic). Automakers hold synthetics to the same oil change intervals as conventional oils. And the oil companies, promise even less. "To give added protection and life to your engine, change your oil every 3000 miles." This same language appears on the back of both Penzoil Synthetic and conventional oils. Valvoline synthetic makes a similar recommendation. (commentary: Since 1972 AMSOIL is the ONLY synthetic oil manufacturer in the world to guarantee 25,000 miles or 35,000 mile oil change intervals and utilizing full PAO synthetic technology exclusively).
Synthetics do get one unambiguous endorsement: Corvettes, Porsches, Vipers, and all AMG models from Mercedes-Benz come with Mobil 1 as the factory fill.
Most synthetics mention GM 4718M in their list of claims; that's the unique spec created by General Motors for Corvette oil. It's a high-temperature requirement that tolerates less oxidation (thickening) and volatility (boil-off) on a standard engine test called Sequence 111E according to engineer Bob Olree of GM Powertrain. (note: AMSOIL 0W-30 far surpasses GM's 4718M spec).
But don't expect to learn such details on any label (again, except for AMSOIL which clearly states test results on the back of every bottle of Series 2000 0W-30 and 20W-50 synthetic). Mobil 1 at least uses straight forward declarative sentences. Most of the others read as though they were written by a lawyer looking for an escape clause. Why else would the following claim be so rubbery? "Penzoil Synthetic motor oil is recommended for use in all engines requiring ILSACGF-1, GF-2, API SJ, SH, or SG, and in engines requiring oils meeting GM 4718M." Okay, but does it actually pass those standards?
"Yes" says James Newsom, Penzoil's motor-oil product manager.
Castrol Syntec, on its label, "exceeds" every standard it mentions. Hmm. Now that the meaning of "is" is in play, I have to wonder, does Syntec meet those standards as well?
"It does" says Castrol's Julie Ann Oberg. While I have her on the phone, I ask if there will be a Syntec price reduction now that the lower-cost base stock has been substituted for the old synthetic. She says no.
End of article.
Bill,
Old Mar 7, 2004 | 02:25 PM
  #26
charlie1935's Avatar
charlie1935
I seem to remember Mobil 1 advertising 25000 mile oil changes when it was introduced, what happened?
Old Mar 7, 2004 | 04:29 PM
  #27
dustyloins's Avatar
dustyloins
Hall of Fame Member
Thanks for the info!! Next time I take it into the dealer and they try to brush me off with that rubber pad excuse, I'll just tell them, "Hey, I been talking to this Dodge mechanic and he says......"!!![sm=smiley36.gif][sm=smiley36.gif][sm=smiley36.gif]
Old Mar 7, 2004 | 04:31 PM
  #28
dustyloins's Avatar
dustyloins
Hall of Fame Member
Well, I THOUGHT I knew a lot about oil.......[sm=smiley29.gif][sm=smiley5.gif]
Old Mar 7, 2004 | 05:12 PM
  #29
sgbofav's Avatar
sgbofav
I did too, until I started reading the threads at www.bobistheoilguy.com
Here is one more extended drain intervals with a turbocharged engine:
8000 miles 00 Audi S4 (Amsoil) http://theoildrop.server101.com/cgi/...c;f=3;t=000473
Old Mar 7, 2004 | 08:22 PM
  #30
dodgemech's Avatar
dodgemech
Bill, thanks for helping me out there. I'm not much for long posts-just the facts. It's nice to have someone else bring all the ammo.
