towing with cruise on or off?
Old Jun 19, 2005 | 01:08 AM
ramfan5.9's Avatar
ramfan5.9
Default towing with cruise on or off?
so if your towing does it matter if you put your cruise control on or off
and how about overdrive too
will either do any harm if you have them on/off
thanx
Old Jun 19, 2005 | 01:41 AM
nickoman01's Avatar
nickoman01
The Only Elite DF Member
Default RE: towing with cruise on or off?
i don't see why it would be problem at all. OK a truck is towing, it may be more weight, but how it is different then a minivan full of adults. the added weight shouldn't hurt it.
Old Jun 19, 2005 | 01:58 AM
ramfan5.9's Avatar
ramfan5.9
idk, my old man told me to ask so i did
Old Jun 19, 2005 | 02:03 AM
nickoman01's Avatar
nickoman01
ask a ram driver. i do alot of things my own way
Old Jun 19, 2005 | 02:14 AM
sagebrush's Avatar
sagebrush
Having the overdrive on all the time while towing will cause the trans to shift excessively which in turn can burn up the trans the same goes for going up steep grades you do not want your vehicle in overdrive when the trans is consistently looking for a gear which will and can cause overheating. As for the cruise control I can see the same thing occur as with the overdrive any small incline will cause your vehicle to loose momentum and then we have the same as with overdrive. It would be better to control the speed with your foot.
Old Jun 19, 2005 | 02:35 AM
nickoman01's Avatar
nickoman01
not gonna argue with that. not only does he have an answer, he also has an explanation. o BTW welcome to the site
Old Jun 19, 2005 | 02:42 AM
ramfan5.9's Avatar
ramfan5.9
sounds good
thanx man
Old Jun 19, 2005 | 06:13 AM
nickoman01's Avatar
nickoman01
it makes sense when you think about it. transmission are expensive too. don't do it
Old Jun 19, 2005 | 03:58 PM
ramfan5.9's Avatar
ramfan5.9
my dad says he "has to use overdrive when on the pike becuase otherwise his RPMs are to high" i asked him how high he said "over 2k"
over 2 doesnt seem that high
Old Jun 21, 2005 | 04:00 AM
Trippen's Avatar
Trippen
Not only the exssive shifting but as my dad allways said...If its in the owner Manual not to do it then dont.....By the way its also on the drivers visor....
