prestone antifreeze
Old Jul 12, 2005 | 11:32 AM
dak0ta_g33k's Avatar
dak0ta_g33k
Default prestone antifreeze
i somehow went low on coolant in my 2003 3.9L v6 dakota. i had switched out my thermostat 1000 miles before and know that is red colored--just not sure if it's dex-cool or something else. all the nearby auto store had were the green antifreeze so i chose the prestone one that said on the bottle "mix with any color antifreeze". i looked in my owner manual and of course the store didn't stock the part number for coolant suggested.
i've only gone 12 miles after topping off the antifreeze and still haven't found the suspected leak.
so my question is am i ok with the mix of olde coolant (RED) and prestone (GREEN)?
Old Jul 12, 2005 | 06:24 PM
moparturd's Avatar
moparturd
Default RE: prestone antifreeze
I've always been told NOT to mix them.
Old Jul 12, 2005 | 07:44 PM
ramfan5.9's Avatar
ramfan5.9
maybe see if a dealer has the part number for the correct anifreeze?
Old Jul 13, 2005 | 12:18 PM
thump186's Avatar
thump186
prestone does make a multi vechile coolant but it is yellow in color. i'm going to change mine out shortly and after the flush i'm switching mine to the good old green glycol.
Old Jul 13, 2005 | 07:47 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
i know that someone makes a coolant that is supposedly mxable with anything, but im not sure who makes it
Old Jul 14, 2005 | 01:14 AM
thump186's Avatar
thump186
ORIGINAL: BadStratRT
it is prestone pat...
Old Aug 1, 2005 | 11:01 PM
mackdaddydak318's Avatar
mackdaddydak318
i've never heard any complaints about the "mix with any color" anit-freeze and prestone and peak makes that there are probably more but those are the ones i know of
Old Aug 4, 2005 | 07:15 PM
Dr.Dodge's Avatar
Dr.Dodge
I just went to a seminar at the local NAPA parts store last week. They were showing off the Prestone "mixes with any colour" antifreeze. I have tried to mix Dex-Cool with reguar antifreeze and they will actually separate, given time. This new stuff blended perfectly. Only time will tell if it is as good as they say.
Jeff
Old Aug 5, 2005 | 08:31 AM
casper's Avatar
casper
Prestone does make a antifreeze for all cars, just make sure you are using the right stuff, if you don't it will rot the radiator and seals,
Old Aug 6, 2005 | 12:05 AM
thump186's Avatar
thump186
i actually know alot of people ,auto techs alike that are flushing out dex cool type coolant for the regular green glycol coolant due to the fact that dex cool type formulas contain alot of silica and are causing acid type problems with aluminum motors over time.
