Reflash ?? : Dodge Colt Vista
Old Sep 8, 2005 | 12:56 AM
rr66's Avatar
rr66
Default Reflash ?? : Dodge Colt Vista
had my injectors ('89 colt vista 2.0) at a local shop - he was going to test them. found out last night though that i had no current at the # 1 and #2 injector connector (so i decided to pick up the injectors) i was telling the whole story and a salesman shows up , but he mentioned that i may need to reflash the EEPROM. did not figure that i could do that; thought he said something like doing the KOKO test would also do that.
Does anyone know if this is true; or How do you reflash the EPROM. ??
well, anyway i came back home and decided to check continuity from the injector (neg) to the ECU (think it is called MPI (multi-port injection) Control Unit, for this vehicle). Good continuity.
Anyway, plugged the connector back into the ECU and checked with a good ground to the battery. Circuit showed good.. THEN, made the normal check at the injector, and LO and BEHOLD, the circuit gave a GOOD voltage reading. well, i hope it was good (not for sure of the exact reading (using analog)). will put everything back soon, and see how it runs (HAD a terrible miss before - and everything else checked OK - too much to list right now).
Did removing the connector at the ECU somehow reset to make thing work ???????
Old Sep 27, 2005 | 05:24 PM
rr66's Avatar
rr66
Default RE: Reflash ?? : Dodge Colt Vista
now have a fuel pump that is out. Sigh!
