radio install now dome lights don't work
Old Nov 24, 2005 | 01:08 PM
Dobi's Avatar
Dobi
Default radio install now dome lights don't work
I installed a radio today in my 2000 Ram. Using wire harnesses and everything, no hack jobs.
At first it didn't work, so plugged the stock radio back in, it worked fine, then rechecked everything put the pioneer in and it still didnt' work so I put the stock one back in and it didn't work. So I get the voltmeter out and find out the orange main power wire wasn't working. So I check all my fuses, Somehow I popped the one to the fuseblock. replace it and still no power to the orange wire. So I run my own 12v line jumping off that same fuse to the radio. Hook it up and it all works fine.
Now my dome lights aren't working. When I try to turn them on I can hear something trying to click on behind the dash, but they don't turn on. I checked all the fuses under the dash and all are find. The dash lights still work and can adjust the brightness on them .. and I puled out the lights and they work fine.. When rolling the dome light switch up, it sounds like some sort of relay is trying to turn them on...
They don't work when I open the doors either.
any help on how to fix this? I have a hard time believing that all 3 interior lights blew at the same time...
Old Nov 25, 2005 | 02:54 AM
casper's Avatar
casper
Default RE: radio install now dome lights don't work
Sounds like you bought a bunk wiring adapeter. Are all the fuses still good??
Old Nov 29, 2005 | 04:45 AM
pacifica_kid's Avatar
pacifica_kid
maybe the noise you hear is a relay behind the dash..
