Headlights stays on
Old Nov 25, 2005 | 11:14 PM
crambo's Avatar
crambo
Default Headlights stays on
Hi all,
I have a problem with my 1997 1500 Dodge Ram pickup-- a headlight malfunction. The headlights stay on and will not shut off unless I remove the corresponding fuse. Is this a problem with the switch or a relay? Although I bought the truck used three years ago, there is no additional added lighting and I did not have any additional lighting added. Does anyone have any ideas as to the problem and/or how I can troubleshoot the problem? Thanks.
Old Nov 26, 2005 | 03:57 PM
casper's Avatar
casper
Default RE: Headlights stays on
I would say its a bad switch or relay. Check both of them. Its a pretty simple system. The only other thing it could really be is a short somewhere.
Old Nov 26, 2005 | 08:10 PM
CarputerGeek's Avatar
CarputerGeek
Didn't those trucks have a recall on the headlamp switch.....I think so.
Old Dec 24, 2005 | 10:51 PM
bmxox's Avatar
bmxox
in my 04 sometimes the lights stay on. im pretty sure its the switch because if it turn the switch back on and off a few times they finally go out, or if i just turn it kinda hard the first time they go out. i wonder if theres a recall on the 02-05 switches as well?
Old Dec 25, 2005 | 07:10 PM
Silver Eagle's Avatar
Silver Eagle
On the 04, if you turn off the lights before you shut off the engine they will turn off, but if you turn off the lights after you turn off the engine the light's will stay on. This may be the same on older trucks as well.
Old Dec 26, 2005 | 03:58 AM
bmxox's Avatar
bmxox
ORIGINAL: Silver Eagle
Will they then eventually go off? I thought there was a problem with the switch because when I do that, and then switch them on and off a few times they go out. The first night it happened to me I was only in the house a few minutes before heading back out and I realized they were still on but I had turned the switch off. I dont mean to hijack the thread.
Old Dec 26, 2005 | 04:29 AM
Chump's Avatar
Chump
From what I see in my wiring diagrams power comes from the fuse to the headlamp switch, from there to the dimmer switch and from there to the headlights. I would think the headlight switch is bad also.
