ram quit
Old Apr 18, 2004 | 01:51 PM
charlie1935's Avatar
charlie1935
Default ram quit
The other night my Ram would quit and then start running again. when I got in town I would start it normaly when it died. 1 and 1/2 blocks from home it quit and wouldn't start anymore. I pushed it home, made me wish I was 40 or 50 years younger. After checking relays with a multimeter, Finally found a bad fuse in the power distribution center. The fuse was intact where it is supposed to blow. Checked bad with ohmeter, so evidently it came apart where it isn't visible. I've had the old type fuses do that before, but not the type we have nowdays. Has anybody else had this happen?
Old Apr 23, 2004 | 05:12 PM
moparturd's Avatar
moparturd
Default RE: ram quit
I've had that happen before as well. What year Ram do you have, and which fuse was it?
Old Apr 23, 2004 | 09:52 PM
dodgemech's Avatar
dodgemech
Yep, I've chased those many times.
Old Apr 29, 2004 | 02:26 AM
charlie1935
My Ram is a 96, the fuse that was bad was one of the ignition fuses. I foeget which one, they are next to each other.
Old May 1, 2004 | 12:43 AM
BigBlueOne's Avatar
BigBlueOne
My Ram is a 96 also. I got myself stranded with a blown Engine Controller fuse in the Power Distribution Center. It seems I caused this myself. [:@] I have the open element K&N FIPK and the mounting stud rubbed through the wiring harness on the cowl. After re-wrapping the bare wire(s), tie-wrapping the harness further back under the cowl, and replacing the fuse, everything was back to normal.
Old Aug 17, 2005 | 05:06 PM
rcone4u's Avatar
rcone4u
I have the same problem with a 96 Intrepid and have checked everything I could think of! if some one know what might cause this please let me know! I have checked the wireing and everything seems to be fine..... the wire isnt grounded or anything... thanks!
