OK guys I think I screwed something up?
Old Dec 19, 2005 | 09:47 PM
horsepower_scott's Avatar
horsepower_scott
Default OK guys I think I screwed something up?
I changed the air filter & spark plugs on my 1995 Neon. Now it won't start. It tries to start but won't. Sounds like the timing is off. Any suggestions?
Thanks,
Scott
Old Dec 19, 2005 | 10:05 PM
casper's Avatar
casper
Default RE: OK guys I think I screwed something up?
Well if thats all you did I would say you switched a wire or 2 on the wire swap. If it was running before you xcrewed with it, and now it isn't, you screwed it up. Those are words to live by.
Old Dec 23, 2005 | 10:08 PM
bmxox's Avatar
bmxox
well your timing wouldnt magically just change by swapping plugs and air filter. its been a few days since this post so you most likely have it fixed by now but if not double check all your plug gaps, if 2 or more are closed, due to the box being dropped or something its not going to start. also double check your firing order, make sure you didnt cross your wires when you had them off.
Old Dec 23, 2005 | 11:26 PM
Silver Eagle's Avatar
Silver Eagle
check your coil wire.
Old Dec 24, 2005 | 03:45 AM
bmxox's Avatar
bmxox
ORIGINAL: Silver Eagle
im pretty sure if its a 2.0 neon there is no coil wire, as its simply a coilpack and there are just 4 plug wires, someone correct me if im wrong.
Old Dec 24, 2005 | 08:07 AM
Sanguinius's Avatar
Sanguinius
Yeah I think it's a coilpack too. Check the firing order bet there are a couple wires wrong.
Old Dec 26, 2005 | 07:03 PM
hydrashocker's Avatar
hydrashocker
Could be non OEM plugs and the computer isn't recognizing them. Try using OEM plugs.
Old Dec 26, 2005 | 11:09 PM
05srt4acr's Avatar
05srt4acr
Sounds like the coil pack to me. I've torn alot of 2.0's down and I've always run in to that problem.
Old Dec 27, 2005 | 04:59 PM
casper's Avatar
casper
The neon does have a coil pack, thats not the problem. Take a 4cyl motor and swap 2 plug wires, its gonna run like ****. Thats all he did.
