tires
Old Apr 25, 2004 | 06:31 PM
cool96ram's Avatar
cool96ram
Default tires
what is the lowest profile tire that i can use on a stock 16" dodge ram wheel and safetly drive around on. i want to lower it and i need lower profile tires for the time being.
Old Apr 25, 2004 | 11:59 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: tires
the issue isnt how low you can safely go, you just have to make sure that the tire you buy has a load range strong enough for your truck. however, i have 205-40zr-17 on my stratus, and i am actually a bit over the max weight listed for the tire i have, and ive had no problem. any tire store should be able to tell you the max weight for whatever tire you want to get.
Old Apr 27, 2004 | 12:31 PM
cool96ram's Avatar
cool96ram
Default RE: tires
ya but i need to know what size i can fit on stock 16 inch ram wheels
Old Apr 30, 2004 | 09:18 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: tires
i got ya...figure out what tire you want, and check with the brand, depending on the width of the rim. for instance, my yokohamas, 205-40-17 require at least a 6 inch rim im now going to a 225-45-17, and ive seen some that require a 7 inch, and some require a 6.5 inch. depends on brand. if you know of a certain tire, let me know, and ill look in a book at work.
