rear end howling noise
Old Jan 12, 2006 | 02:02 AM
ineedamotor's Avatar
ineedamotor
Default rear end howling noise
i have a 1998 r/t, every time i am coasting and give it a little gas it sounds like my transfure case is howling? i think it may be the yoke pin.
anybody have an idea?
thanks, derek
Old Jan 12, 2006 | 09:28 PM
06ChargerSXT's Avatar
06ChargerSXT
Default RE: rear end howling noise
Did it do this on a full moon.J/K
You might want to chek the fluid
you might be low.
Old Jan 13, 2006 | 01:21 AM
ineedamotor
maybe
Old Jan 13, 2006 | 01:38 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Either that or you have a gay vehicle.
Sorry, I couldn't resist.
No more jokes, I promise!
Dusty
Old Jan 14, 2006 | 08:21 PM
89Daytona's Avatar
89Daytona
When my 98 Durango had a howling sound in the rear it turned out to be a toasted rear differential.
Check the fluids for metal particles, if you find some then you know where the problem is.
Old Jan 20, 2006 | 02:00 AM
Caprice SS's Avatar
Caprice SS
ORIGINAL: ineedamotor
thanks, derek
That's usually not a good sign. Have someone check the backlash on the gears. And along the lines of what 89Daytona said, the mechanic might find some metal particles while he checks the wear pattern & condition of the gears.
