HELP! Remote start program guide
Old Mar 6, 2006 | 01:13 AM
Roddy's Avatar
Roddy
Default HELP! Remote start program guide
I had a remote start (MOPAR) installed by the dealer on my 2005 1500 RAM with the HEMI, the paperwork did not have a program guide. I'm having problems with the remote start system. Push the button two times to start the truck and the horn honks 5 times and the truck won't start. The dealer is 70 miles away so I would rather not drive to them if some one out there knows of a program guide on the web. Or could help me with the programing...
THANKS!
Old Mar 6, 2006 | 10:23 PM
06ChargerSXT's Avatar
06ChargerSXT
Default RE: HELP! Remote start program guide
how is the lay out on the remote
mine is not a dealer part but its lay out is
lock /unlock
trunk/ key symbol to start
to start mine I hold the key symbol down for 3 seconds let go
then it starts to turn off you just hit it once shuts car down horn beeps.
Try to hold down for 3 sec then release.
Old Mar 7, 2006 | 11:31 PM
06ChargerSXT
Any Luck with it
Old Mar 11, 2006 | 12:09 PM
Roddy's Avatar
Roddy
I tried and it still didn't work. I called the dealer and told them what was happening and was told there was a recall for the MOPAR dealer installed unit. (Bad Brain).[&:]
Was also told there is no programing guild for this unit, it is set by the factory with not options.
Thanks for the help!
R
Old Mar 12, 2006 | 12:24 AM
LB's Avatar
LB
If you don't mind what did the dealer charge you for the unit and install? I have an '05 Dakota I want to either have it done or try it myself.
Also, do you have a sentry key?
Thanks,
LB
