PLEEAASE HELP!!! Crazy problems
Old May 31, 2006 | 12:12 AM
timwag2001's Avatar
timwag2001
Default PLEEAASE HELP!!! Crazy problems
I've got a 01 Ram. I've put a throttle body spacer, apc air intake, electric fan, jet chip, 8 mm taylor spark plug wires (which weren't the exact lengths as the stock wires) ceramic plated gibson headers, High-flo Magnaflo cat, and dual fowmasters . Ok, all that being said, My truck idles sporadically from around 600 to 1200 rpms and when I drive I can feel it rev up. It seems to do it more when i have cruise controll on. When i first recognized the problem i took the chip out... It still did it but not as much. I'm lost. I dont know what to do. I dont get any trouble codes either with or without the chip.
Old May 31, 2006 | 01:40 AM
buckw1's Avatar
buckw1
Default RE: PLEEAASE HELP!!! Crazy problems
Takeoff the TBI spacer and see what happens....
Old May 31, 2006 | 06:32 AM
The Burning Rom's Avatar
The Burning Rom
Throw the JET chip away...they don't work
Also, take the TB spacer off (as mentioned) and use it as a paper weight. They don't work AT ALL on multi-port injected motors
If that doesn't fix your problem, post again.
Old Jun 1, 2006 | 01:59 AM
timwag2001's Avatar
timwag2001
found a loose connection on the wiring harness for my iac... do you think that could be the problem. Cant take off TB yet. I lost the original bolts. I took out the jet chip and it was still doing it but not as bad. I found the problem with the IAC and started it back up with no problems. Because it was doing it worse with the jet chip in i put it back in and havent had any problems yet. Do the Jet chips really suck that bad? I havent really seen that many bad reveiws for them.
