Hemi head id
Old Jul 2, 2004 | 06:54 PM
gunnar@patriotperformance's Avatar
Default RE: Hemi head id
the deal is i have some of these heads that have bigger intake and exhaust ports, and also these heads appear to be off a larger bore motor than the others i have.
moparturd's Avatar
moparturd
Unless I'm really confused, which isn't out of the question, it would most likely be inside the rocker pedestal area. I'm not even sure that the newer heads would have them.
Old Jul 2, 2004 | 06:56 PM
sorry, no date cast there.
Old Jul 2, 2004 | 07:02 PM
moparturd's Avatar
moparturd
Where are the casting numbers located? I can look at the heads on my truck and see if they match-up to those.
Old Jul 2, 2004 | 07:06 PM
right side head,above the last 2 exhaust ports.
Old Jul 2, 2004 | 07:14 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
I also wouldnt think that the heads, jsut because they are on the same engine, are from the same batch or run date.
Old Jul 2, 2004 | 07:49 PM
this isnt going to be like a difference in run date. these heads are like for a big bore motor like a 4.080 bore
Old Jul 2, 2004 | 07:56 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Wait..im a bit lost here...are these for a 5.7hemi or a BB hemi?
Old Jul 2, 2004 | 08:32 PM
5.7
Old Jul 2, 2004 | 11:36 PM
moparturd's Avatar
moparturd
gunnar. I could only find a # on the drivers side, rear part of the head. To further confuse things the # is 53021609BA. That is on the truck you see below.
