wheel question
Old Jul 30, 2004 | 01:19 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: wheel question
i already have the rims..theyre at home..with new tires. is the act of changing those studs any worse than changing the studs on the RT?
Old Jul 30, 2004 | 01:28 PM
moparturd's Avatar
moparturd
It's as bad, plus you have to pull the axles in the rear to get at the studs. Did you get rims from the dealership? I've been thinking of some bigger rims for the Intrepid.
Old Jul 30, 2004 | 01:50 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
id rather not say on here how i got the rims. i got the tires from one of lindas friends. i didnt know id have to pullthe axles. that Is moretrouble than its worth. the rims are even in the boxes..i just dont have the jeep wheel centers, and i havent found a ram center in stock thatlll fit in the center hole.
Old Jul 30, 2004 | 04:09 PM
moparturd's Avatar
moparturd
What's the width? I wouldn't put them on unless they are 7" or more.
Old Jul 30, 2004 | 04:11 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
i believe they ae either 7 or 7.5 i knwo they are 7 something...i havent taken that good of a look at them.
Old Jul 30, 2004 | 04:15 PM
moparturd's Avatar
moparturd
What will you take for them? Will you consider a trade with my Neon rims and tireshttps://dodgeforum.com/tm.asp?m=3511...=1&key=&#35111? Lets talk.
Old Jul 30, 2004 | 06:09 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
what do you want to put them on? theyre truck rims and tires..like 245-65-16or something like that..bfg a/ts or maybe a cheaper modell of the same brand. linda brought themhome..i havent even looked at them..
Old Jul 30, 2004 | 06:26 PM
moparturd's Avatar
moparturd
I was thinking of putting them on the Intrepid if the offset wasn't too much different. The car already has 16 x 6 rims. I would like a bit wider tire on it.
Old Jul 30, 2004 | 06:29 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
i believe the offset is 43.8 or so..i know its stamped on the back, as is the size..im pretty sure they are 16x7 and 43.8 offset.
Old Jul 30, 2004 | 07:05 PM
moparturd's Avatar
moparturd
I think the Intrepid wheels are actually 7" wide anyway. Oh well.
