Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Fire order 4x7 swap
Old Sep 24, 2006 | 08:21 PM
Wilks's Avatar
Wilks
Default Fire order 4x7 swap
Recently on Power Block TV they changed the firing order on a Chevy engine (Swapped cams to change cylinders 4 and 7 in the order) any idea if there is an application for Dodge 5.2?
Old Sep 24, 2006 | 09:44 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: Fire order 4x7 swap
.....why would you want to? [&:]
Old Sep 25, 2006 | 01:13 AM
Wilks's Avatar
Wilks
They gained 30hp on the Dyno
Old Sep 26, 2006 | 06:38 PM
The Burning Rom
They gained that 30 horse from putting a cam in They didn't gain it from swapping the firing order. And besides, that's a chevy motor. Different breed of animal [8D]
You can gain up to 45 with the Mopar Performance cam and the right intake mods
Old Sep 28, 2006 | 05:44 PM
Wilks's Avatar
Wilks
Right, the new cam changed the firing order of # 4 and 7 cylinders. Maybe it's just a Chev thing. What kind of cam and intake mods would you recommend? Right now I have Stage II Jet chip, 180 thermo, K&N filter, 3†exhaust w/ Magna Flow muffler, high flow cat, Accel coil. On a 97 318 w/ 90k miles
Old Sep 28, 2006 | 06:23 PM
The Burning Rom
Dump the jet chip - http://www.rm-indy.com/Jet_Sucks.htm
I would suggest a mopar M1 intake manifold, a throttle body from www.thefastman.com, and a K&N FIPK.
As for a camshaft, I recommend this one: http://store.summitracing.com/partde...+0&appfilter=1 It's EXACTLY the same as the Mopar Performance camshaft that's no longer in production. It's a very good cam.
I would also suggest a set of Gibson headers and/or possibly going down in exhaust size a little. 3" is borderline on being too large for the 318. You actually see some loss in torque by running it.
Old Sep 28, 2006 | 09:34 PM
Wilks's Avatar
Wilks
Default RE:
Thanks for the tips. I’ll have to look into some of those parts. Yeah with the jet chip I’ve never really been able to check if it really worked. I did a few mods at the same time.
