Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
98 grand cherokee
Old 12-03-2018, 08:40 PM
Josh Castaneda's Avatar
Josh Castaneda
Josh Castaneda is offline
Default 98 grand cherokee
I have a 98 grand cherokee with the 4.0 when i go to start it i have no spark and none of the gauges work. I have replaced crank sensor and cam/ignition pick up sensor and still have no spark
Old 12-04-2018, 09:36 AM
HeyYou is online now
Dodge Forum Administrator
Received 3,179 Likes on 2,932 Posts
Any lights in the dash come on?
Old 12-04-2018, 10:19 AM
jkeaton is offline
Did this just start happening? Was it doing this before replacing parts?
Old 12-25-2018, 12:28 PM
Moparite's Avatar
Moparite
Moparite is offline
X2! need more info. Do you have any codes? Do you hear the fuel pump prime the system? Try the dash test procedure and see if it works.
This may not work on a 98 but try it(codes)
https://www.quadratec.com/jeep_knowl...article-24.htm
Old 03-15-2019, 01:00 PM
PR1AWRet's Avatar
PR1AWRet
PR1AWRet is offline
Did you use Mopar products? On my 98 I replaced the crank sensor 3 times with other parts stores before I went to a Mopar one and it fired right up. What led up to this?
Quick Reply: 98 grand cherokee
