Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
2016 TrailHawk Brake Issues
Old Jul 23, 2020 | 09:14 PM
DirtHogg's Avatar
DirtHogg
Default 2016 TrailHawk Brake Issues
Question,2016 Jeep Cherokee TrailHawk (wifes ride).Decided to get very hot passenger side rear .pulled temp with laser 248 c .Suspected a bad bearing maybe.But now has changed to drivers rear.All others are at 40 degrees c.Could anyone shed some light on what i should start with?Was thinking new rotor/calp/pads ect/bearing .When the 1st instance happened on passenger rear.Any help would be super appreciated.
Kindest Regards
DirtHogg
Old Jul 24, 2020 | 08:46 AM
Are there individual lines going to the rear brakes? One for each side, from the ABS module?
Old Jul 24, 2020 | 02:25 PM
DirtHogg's Avatar
DirtHogg
Thank-You for responding.Yes seperate lines with some sort of valve inline.Peaccock valve?maybe?Do caliper plunger pins fail or get gummy,was thinking maybe change out pins?
Old Jul 25, 2020 | 08:50 AM
They do get sticky, but, just taking them out, cleaning them, re-lubing, is usually all it takes to get them to behave.
