Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
Transmission codes P0733, 0734 and 0735
Old Feb 25, 2023 | 11:36 AM
Jeeperross's Avatar
Jeeperross
Default Transmission codes P0733, 0734 and 0735
Above CEL codes while wheelin in snow and the won’t clear, looking for ideas to solve issue. Changed ATF, wasn’t low btw. Prior to throwing the 3 codes I’ve been seeing the following symptoms when off-road. The trans will forget how to shift automatically. Manually changing gears doesn’t work and if in Drive trans will fail to start in first, second etc making for a very slow acceleration since it’s “stuck” in high gear. Turning the engine off and back on will clear the shifting problem temporarily. When the 3 codes above popped, clearing the shift failures by restarting the engine only worked about 50% of the time. Currently trans is operating normally except I have these 3 codes. Help 🤔
Old Feb 26, 2023 | 09:45 AM
What are you driving?
Old Feb 26, 2023 | 10:36 AM
Moparite's Avatar
Moparite
P0733 Gear Ratio Error in 3rd
P0734 Gear Ratio Error in 4th
P0735 Gear Ratio Error in 4th Prime
You can get a better idea what the issues is by looking them up here.
Old Feb 26, 2023 | 06:19 PM
Jeeperross's Avatar
Jeeperross
2015 JKU Rubicon with 1 T ud60 axles
Old Feb 26, 2023 | 06:25 PM
Jeeperross's Avatar
Jeeperross
Thanks Moparite, nice in depth info but couldn’t find a solution. In another forum for a different trans but similar codes they called out the input speed sensor which I thought sounded reasonable but I haven’t located it yet in my 2015 JKU wrangler.
