K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
1994 dodge shadow... please help
Old May 10, 2007 | 03:36 AM
demonboy279's Avatar
demonboy279
Default 1994 dodge shadow... please help
Ok I have a 1994 Dodge Shadow with a 2.5L Its has 98,000 miles on it.
So heres the story and problem.
I just recently purchased the car. And soon after my head gasket blew out. When i took the top half apart i realized i had to replace every gasket on the top and all the hoses because they were dried out majorly. So after cleaning up and replacing everything I found my vacuum hose diagram didnt show where one of the hoses on the throttle body goes to.
But anyways i dont have 1 hose hooked up (it was already broken off before i started) cant find where it goes. And the only way im hearing on how to put this car back in time is by lining a 0 up in the hole in the bell housing. Ive tried everything i can yet i cant get my car to even fire up. all she does is crank n crank.
What am i doing wrong? what are the possibilties. I badly need help on this.[/align]
Old May 10, 2007 | 10:52 AM
speedyshelby's Avatar
speedyshelby
Default RE: 1994 dodge shadow... please help
Sound like you didn't time the belt with all the sprockets.
Try this and tell me if you got them right.
http://www.thedodgegarage.com/timing_belt.html
Old May 11, 2007 | 01:31 AM
demonboy279
I'm 95% sure i got them right now. I do have 1 question bout it though. The mark in the bell housing. Is it the circle or the stamp mark line?
Old May 11, 2007 | 02:44 PM
demonboy279
where the red line comes out of the throttle body is it its about a half inch to an inch below the 2 beside it
[IMG]local://upfiles/62568/3D1E170527E246E3AA0441E4CF692271.jpg[/IMG]
Old May 12, 2007 | 04:16 AM
speedyshelby
My 94 2.5 tbi spirit looks like it goes like this. Follow the red line to your red line.
[IMG]local://upfiles/39458/E24CA3F8CB4046A386D0382585FBC9F2.jpg[/IMG]
Old May 12, 2007 | 05:05 PM
demonboy279
I believe your right. Thanks man.
I still cant get her running though. I reworked my vacuum lines and checked the tgiming again and today i sprayed some ether in and she fired enough to shoot a flame out the throttle body but she wont start still. and she only occasionally fires up
Old May 12, 2007 | 11:11 PM
demonboy279
Ok thanks for the advice i finally got her running. she has another problem though. When im going up a hill no matter how small it is she loses power and i have to shirt from drive to second and sometimes first. i can put the pedal to the floor and she still loses alot of speed. and shes slow on take off. any ideas??
Old May 13, 2007 | 03:12 AM
Ix Elit3 xI's Avatar
Ix Elit3 xI
Demon, I think your problem is coming from ****ty HP, the shadow depending on 2.2 , 2.5, turbo, and age only has around 100 hp.
You could try replacing your spark plugs,wires, distributor cap, I did that when I bought my 93 shadow, I only had 3 firing plugs hehe.
Old May 13, 2007 | 03:54 AM
demonboy279
I already replaced all plugs wires and the distributer cap she fires blue on all 4 plugs. so thats not the problem. and before my head gasket blew out she ran alot better than she is now i want her back to at least how she was. She is below normal i mean ive seen chevettes and station wagons do better than she is now shes got something wrong with her.
Old May 13, 2007 | 04:46 PM
speedyshelby
when you timed it did you turn it over by hand to make sure the cam didn't get a tooth off?
