K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
PSI Q:
Old Aug 14, 2005 | 05:53 AM
SloShadow90's Avatar
SloShadow90
Default RE: PSI Q:
whats the cheeta action thing??
Old Aug 15, 2005 | 02:29 AM
SloShadow90
Default RE: PSI Q:
can i put a bov on my 2.5L turbo, and how do you know the difference between a turbo I and turbo II
Old Aug 17, 2005 | 07:19 PM
turbospirites's Avatar
turbospirites
Default RE: PSI Q:
turbo 2 has a sensor on the intake right in the middle of the intake and a intercooler t1 doesn't have eather (quickest way to explain it) and yes you can put a bov (blow off valve on a t1 or any turbocharged car) it might allredy have one on there know check in the air box where the air filter is and there will be a vacume hose hooked to it.
Old Aug 17, 2005 | 07:21 PM
SloShadow90
Default RE: PSI Q:
do u have any pics?
Old Aug 17, 2005 | 07:25 PM
turbospirites
Default RE: PSI Q:
I have old pic's of my car www.cardomain.com/id/turbospirites but I cant get back into my acount to post new pic's and stuff on it.
Old Aug 17, 2005 | 07:36 PM
SloShadow90
Default RE: PSI Q:
ohh.. alright on this pic right here can u tell me which hose the bov would come off of?
http://www.cardomain.com/ride/606554 its the 11th pic down... can u like put a box around the hose for me
Old Aug 17, 2005 | 07:50 PM
turbospirites
Default RE: PSI Q:
it's on the air box with a smaller vacume hose going to it, inside the air box take out a little square filter and you'll see a bov *there's also a hose coming from the throttle body to turbo hose to the filter area*. If it doesn't have I have explaned it doesn't have one. the factory one is only good up to 15psi of boost anyway's. There is also info on all this stuff on www.thedodgegarage.com I met Garry D acouple of time's he's a good guy!
Old Feb 19, 2006 | 05:57 PM
wert 91's Avatar
wert 91
Default RE: PSI Q:
well you could go as high as 300 horse out of the TIII or on a common block about 250 horses.I run 14 lbs boost on a mostly stock 2.5 turbo block using a log style intake and a auto tranny with a garret t3 turbine. and the only thing that concerns me is cracking a tranny if i go to a intercooled TII.But i can boost off the line and shift and only lose 2 lbs boost what tranny are you using auto/manual?But i don't want to crank up more power beacuse if i switch to a manual tranny i just lost a lot of value on my laser it is a 1986 laser xt/w t- tops red exterior black interior and mark cross interior only 4000 made and only 200 left that i know of.it only has 64000 miles and if you look under the hood it looks all original. even has the infinity 3 stereo still installed and all the build sheet matches.Except engine block and head came off 1987 lebaron gs convertible but it still is a swirl z782 head
