K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
Idle Issues
Old Jan 12, 2011 | 11:35 PM
82 2tone's Avatar
82 2tone
Default Idle Issues
I have an 82 town and country 2.6l, was running great then all of a sudden it would run so rough at idle it would stall. The next day all was fine, lasted about 3 months then it happened again. Next day it was running fine again. Now about 2 months later it happened a third time and its still idling rough. If I do the brake gas thing to keep it from stalling it will drive fine. So if anyone has any ideas where to start looking I'm all ears. Thanks in advance for your help.
Bob
Old Jan 15, 2011 | 09:39 PM
hemi4spd's Avatar
hemi4spd
carb in need of a cleaning?
Old Jan 16, 2011 | 10:37 AM
82 2tone's Avatar
82 2tone
I don't think it's the carb being dirty, I have sprayed it down with carb cleaner and ran numerous cans of seafoam through it.
Old Jan 18, 2011 | 11:43 PM
hemi4spd's Avatar
hemi4spd
check for corrosion on the connectors to the pickup coil?
have you tested Pickup coil?
have you tested Ignition coil?
is it a timing issue?
Old Jan 19, 2011 | 10:23 PM
82 2tone's Avatar
82 2tone
I haven't really checked anything yet, We are in the -40's here. The car is parked till summer so I'm just trying to find out where to start looking once it warms up. As far as timing goes wouldn't have kept running bad after the first episode?
Old Jan 20, 2011 | 09:12 PM
hemi4spd's Avatar
hemi4spd
thinking more on the lines of ignition timing not mechanical timing
I'll find you the diagnosis/repair tree and post
Old Jan 22, 2011 | 10:03 PM
82 2tone's Avatar
82 2tone
Okay I get ya Any info you can post would be greatly appreciated, Thanks
