K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
Engine 2.2L DOHC Turbo III(224 hp)
Old Nov 22, 2006 | 01:30 AM
jmja9281's Avatar
jmja9281
Default Engine 2.2L DOHC Turbo III(224 hp)
Has anyone ever heard of or seen this engine. 2.2L DOHC Turbo III. I was told it was from a Daytona IROC Z. Also where can I find some pictures
Old Nov 22, 2006 | 06:24 PM
89Daytona's Avatar
89Daytona
Default RE: Engine 2.2L DOHC Turbo III(224 hp)
http://www.allpar.com/mopar/22t.html
http://www.relentlessracing.com/main.htm
You can also make your own DOHC 2.2L engine, by doing a Neon cylinder head swap http://home.comcast.net/~ozspeed/CylinderHead.htm
Old Nov 23, 2006 | 01:19 PM
1994shadowman's Avatar
1994shadowman
ORIGINAL: 89Daytona
If your honestly gonna go through that much work to make your 2.2 DOHC, for the same amount you could drop in a Turbo motor or make your 2.2 MPFI.
Old Nov 23, 2006 | 01:56 PM
89Daytona's Avatar
89Daytona
But with a 2.2/2.5 Dohc conversion you can still add on the turbo and get even more power. So it all depends on how much powwer you want in the end... And the DOHC will get you the extra power without worrying about blowing/rebuilding a turbo.
Old Nov 24, 2006 | 11:13 AM
speedyshelby's Avatar
speedyshelby
neon head is what people do to there 2.2/2.5 when there the stock 8 valves aren't engough. I thought about it but going with the 8 valves. The TIII motor also came in spirit R/Ts. Also it not daytona Iroc Z it daytona Iroc R/T. They did make normal Daytona Iroc that came with a 3.0 V6 or a 2.5 T1 motor.
Old Nov 25, 2006 | 04:58 AM
jmja9281's Avatar
jmja9281
Hey you guys thanks for your replies. But If I do happen to install a DOHC head would I need to change the CPU. Also which CPU should I use.
Old Nov 25, 2006 | 01:19 PM
89Daytona's Avatar
89Daytona
ORIGINAL: jmja9281
If you have questions you can email the maker of that website http://home.comcast.net/~ozspeed/index.htm (the link is at the bottom of the page).
From what is on that site it doesn't look like he says anything about a different computer, but by using the neon intake and fuel rail you need 4 injectors which means you need the wiring harness and computer to drive them. You could use a Megasquirt to run it and that would make the addition of a turbo easier.
Old Nov 27, 2006 | 11:47 AM
speedyshelby
Stock turbo are all 4 injectors. You can run a neon head on stock eletronics. Most people go with a 2.5 for extra fuel but you can get custom cal for anything you put together.
Also stock TIII engine didn't have a distriber they ran a coil pack. You can run a distriber on a Non TIII but a true one doesn't even have a whole for it.
Old Nov 27, 2006 | 03:28 PM
89Daytona's Avatar
89Daytona
ORIGINAL: speedyshelby
But you would have to have the turbo engine to begin with. NA's are all TB injection.
Old Nov 30, 2006 | 01:45 AM
speedyshelby
My best suggestion would start with a standard 8 valve turbo setup before going with any of 16 valve options.
