K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
90 Dodge brakes
Old Nov 30, 2006 | 02:10 PM
smartobject's Avatar
smartobject
Default 90 Dodge brakes
1990 Dodge Spirit 2.5L Front disc/Rear Drums
I recently replaced pads and shoes all round, new wheel cylinders on rears, flushed fluid, bled all around.
Also adjusted park brake so it works good.
Pedal still feels spongey and the pedal seems lose a little pressure with my foot on it while car is stopped.
Sounds to me like a master cylinder going bad. Maybe I ruined the seals, when replaced everything and possibly moved the piston too far back into a corroded area of the cylinder???
One more thing -- The red brake light is _not_ on and does _not_ come on when pressing the pedal. I thought it would??
Does any one agree / disagree with my "bad master cylinder" diagnosis??
Thank you,
Lee
Old Nov 30, 2006 | 08:30 PM
89Daytona's Avatar
89Daytona
Default RE: 90 Dodge brakes
Do you mean the brake light on the dash? That is for the parking brake.
You should bleed the brakes a second time, you might still have air in the lines. If that doesn't fix it then master cylinder is most likely problem.
Old Dec 1, 2006 | 03:00 PM
smartobject
Thanks, will check / bleed again. Before, when I had pressure problems the light would come (same one as park brake) because of pressure differences between front /back.
Lee
