What Spark Plugs U guys/gals Recommend?
Old Apr 1, 2007 | 05:22 PM
Racevette77's Avatar
Racevette77
Default What Spark Plugs U guys/gals Recommend?
Last post i said i had lost 2lbs of boost and was gettign some flutter at full throttle / max psi. Yall recommended new plugs and wires could fix the prob. Well a few months ago (5ish) i replaced the plugs and wires with OEM and gaped the plugs at what the old ones were.........which if i remember correctly it was 55. I dont recall when it was i noticed the difference in boost lvls but it has been since i changed out the old w/ the new.
What wires / plugs yall recommend and what gap?
Thanks.
Old Apr 1, 2007 | 11:34 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: What Spark Plugs U guys/gals Recommend?
I've had my MSD wires for three years and they still perform and look like new............as for plugs, you're going to get several different opinions. I know what works well in my car and my wallet is happy as well...........
Dusty
Old Apr 2, 2007 | 01:23 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
you could probably go with about 35-40 on the gapping (i should ask what all modifications you have first, if your too distant you can blow the spark out). and i have heard nothing but great things about the MSD wires. There are a lot of choices out there for plugs
Old Apr 2, 2007 | 04:11 AM
Pressurecooker's Avatar
Pressurecooker
I still have the stock wires but I also have a heat shield. You should definitely get a heat shield to protect the coil pack and wires. I have almost 30K mileage and changed the plugs once about 10K ago. I put in Autolite brand iridium plugs and have been happy. I did that to fix the idle stumble the car has had since new. It helped.It is starting to idle stumble a bit more now and I'm thinking I may want to change the plugs again for this season and gap them a little tighter due to mods I have done, but I have been generally happy with the Autolites so far and have not noticed flame blow out, yet, but I have higher boosts in mind and possible,so I plan on staying ahead of my problems. I will try to be gentle with the wires and keep them. I am a firm believer in the if it aint broke, dont fix it. So IMO pulling the plug wires on and off a lot is where a lot of people induce failures in the wires. I have thus far been rather trouble free and I drive hard. I may go with Autolites again just gapped tighter.
Old Apr 3, 2007 | 12:16 AM
flamingpinhead
Section Moderator
^only argument against certain heat shields is that they block some of the air flow going to the turbo... but i have never read anything conclusive one way or the other, but im still reluctant to put one on
Old Apr 3, 2007 | 05:54 PM
MEandmySRT's Avatar
MEandmySRT
ORIGINAL: flamingpinhead
I bought a "Mopar" coil shield from eBay for $10 that arrived in a factory looking package and it shouldn't block any airflow to the turbo, because it wraps around the coil and only covers the bottom, backside and a tiny edge at the top.
Old Apr 3, 2007 | 06:33 PM
PSI Chick's Avatar
PSI Chick
mopar doesn't make a heat shield
Old Apr 3, 2007 | 11:30 PM
flamingpinhead
Section Moderator
but the guy on ebay said it was a "Mopar" !?!?
