Mopar Stage 2 Upgrade Numbers?
Old Sep 4, 2004 | 03:00 AM
bubba321's Avatar
bubba321
Default Mopar Stage 2 Upgrade Numbers?
Was wondering if anybody knew what kind of 1/4 times I should expect at best on an 04 SRT-4 with only an intake and a Stage 2 Mopar upgrade? What kind of horsepower too? What about Stage 1?
Old Sep 4, 2004 | 01:27 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Mopar Stage 2 Upgrade Numbers?
My install instructions show 240 ponies with the Stage 1 alone. Add a K&N and a Mopar/Borla exhaust and you're probably looking at over 250 horses.
www.modernperformance.com states they believe the actual HP for a stock SRT-4 is probably closer to 250-255 HP based on what they've seen. Mopar has been understating the HP figures to avoid "insurance shock".
If that's true, add 20-25 more HP to the advertised numbers......that would put Stage 1 alone at 260-265 HP.
Old Sep 4, 2004 | 02:36 PM
bigddy9's Avatar
bigddy9
Dusty, you forgot about the extra HP you get from the 3D tail lights and the "racing" antenna!!! Those alone should put you over 300! A couple of yellow stickers and you should be running low 10's![sm=icon_rock.gif]
Danny
Old Sep 4, 2004 | 06:52 PM
PSI Chick's Avatar
PSI Chick
i wouldn't quote those numbers as bible, some dynos are showing differently. we had a dyno day last night and stock srt's were pulling 203-210 fwhp. now yes, everyone dynoed a little low last night (it seemed that most were missing about 15hp) due to insane heat and humidity in the shop. i dynoed my car finally, pulled a 241 on setting 3, 260 with race gas. yes, stage 2 hates the dyno and it was apparent from looking at my dyno sheet, as you could see plain as day that the computer was pulling timing after about 5200 rpms.
magazine and bench racing are great until the dyno sheet tells you the real story...[:@]
Old Sep 4, 2004 | 08:26 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Modern Performance is located in Houston Texas where the temp and humidity are both near "100" this time of the year. I'll take their figures as a general guide until somebody proves them wrong. I've heard of Mopar understating HP figures ever since I was a kid....at least they don't overstate like the "four letter" auto maker did....[sm=icon_cheers.gif]
Old Sep 4, 2004 | 10:07 PM
zeus442's Avatar
zeus442
psi chick is lying to you!! the 03 stock was running 213 stock with boost leaks!!!! fromw what i heard stage 2's are running the 1/4 between 13.2-13.5, you realy should looking into getting an exhaust with the s2
Old Sep 4, 2004 | 10:13 PM
glhs837's Avatar
glhs837
http://www.srtforums.com/forums/show...t=stage+simple
There you go, the most comprehensive collection of Stage 2 times around
It pretty much confirms what Zeuss said, but of course there are variations. As far as power levels, I pretty much just go with the Mopar/Dodge stated numbers as wheel figures.
03 = 215 stock, 230 S1, 265 pump S2, 280 racegas S2 (S2 numbers dependant on Mopar exhuast or better.
04 = 230 stock, 240ish S1, S2 the same.
Old Sep 4, 2004 | 10:50 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Thanks, glhs837, you've come through again!
My life has shown me that what is true for someone else is usually not true for you. Especially when it comes to cars, mods, driving techniques, etc. To some people the SRT-4 is a "drag car", others see it as a kick butt "rally car" and others like to just surprise people on the street...each to their own.
I now am rethinking Stage 2 after blowing the sensor with just Stage 1. Your posting showing no HP gain from Stage 1 to Stage 2 for an '04 is rather disturbing!!!
Old Sep 5, 2004 | 12:53 AM
glhs837's Avatar
glhs837
Whoa, Dusty!!!!!! BIG misunderstanding!!!!!!
I meant that 04s with S2 get the same numbers as an 03 with S2.
Meaning 04 w S2 should be the 265, 280 racegas. Now, as psichick mentioned, S2 and dynos don't get along. The best indicator of the power is the times. Not mine of course, I suck[:'(]
I can say I have almost 10K on my S2 car, other than having to tighten up my piping clamps, no issues. And nothing blown out besides the hotside pipe clamp got loose. I show 16-17 psi every day, actually use my boost gauge to ensure I have no boost leaks
Leaks show as higher boost levels
Old Sep 5, 2004 | 03:04 PM
PSI Chick's Avatar
PSI Chick
i'm lying? would you like to see my dyno sheet as proof? i wasn't the only s2 car there, there were 3 of us and i got the highest numbers of everyone there (other than the one upgraded turbo car). yes, the dyno was giving low numbers that night, everyone has agreed on that. but those are the numbers that we were seeing, and that was running in 86 degrees and 30in of pressure, not exactly ideal, and also not that far off from what modern probably runs their dynos in. was the dyno conservative? yes. but did it lie? no.
