bad wastegate?
Old Apr 14, 2007 | 03:33 AM
turbosrt's Avatar
turbosrt
Default bad wastegate?
what are the symptoms of a bad external wastegate? i got the turbonetics evolution and no matter what i do i cant get past 14pnds i disconected the vac hose from turbo to w/g and only boosts 10,11psi's because of the w/g spring, plug the hose back up and i get 14pnds cant go any higher, already did boost leak test and tried anotger boost controller.. so how i know when my wastegate is somewhat stuck open??[/align]
[/align]
Old Apr 14, 2007 | 03:01 PM
monstab757's Avatar
monstab757
Default RE: bad wastegate?
From what I've read on this site especially comming from PSIchick, if you cant boost past what your spring is rated for, then its probably a bad wastegate. For example, the stock wastegate on our cars have a 7lb spring, so if you cant boost past 7psi you might consider getting a replacement. Dont take this as the gospel though, cause I'm still learning.
Old Apr 14, 2007 | 11:10 PM
turbosrt's Avatar
turbosrt
i can get up to 14psi max and the spring is a 10pnd sprng
[/align]
Old Apr 15, 2007 | 10:11 PM
turbosrt's Avatar
turbosrt
so anyone wats to chme in?
[/align]
Old Apr 15, 2007 | 10:38 PM
monstab757's Avatar
monstab757
Could be a leaky bov. What type do you have?
Old Apr 15, 2007 | 10:54 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
especially if you have the blue plate installed, if its not perfectly set on there right, its prone to be quite leaky
Old Apr 15, 2007 | 11:39 PM
turbosrt's Avatar
turbosrt
hks ssq
[/align]
Old Apr 16, 2007 | 03:00 AM
srtratblock's Avatar
srtratblock
looks like you could ajust w.g. a half turn at a time, this should let your boost go a little higher, plus it should spool up faster from idle.this is what i did with mine and it did help spool up and boost pressure. half turn plenty at a time,because you can get a big boost spike.
