Advise plz
Old Apr 17, 2007 | 01:44 AM
killerBsrt's Avatar
killerBsrt
Default Advise plz
wuts going on evryone! i jus bought my srt4 and i bought 577cc stage 1 injectors and a agp wastegate i wanted 2 set my psi @ 18 psi! is this safe? or wut is best and wut can my car handle b4 i blow the engine up? lol thanks!
Old Apr 17, 2007 | 02:04 PM
emilysrt's Avatar
emilysrt
Default RE: Advise plz
dont go past 16psi to redline on the stock fuel system! i peak at 18-19 and i hold 14psi to redline! if you want to boost more get a wideband,safc,fuel pump and have it tune right so your not going to blow up your **** lol.
Old Apr 17, 2007 | 07:55 PM
killerBsrt's Avatar
killerBsrt
so how would i know when i redline @ about14 psi? wut psi should i peak @ inorder to hold 14 psi @ redline? and how much HP and Torque will i get out of it? pretty much i want to know wut peak psi i should be running inorder to hold 14 by redline? lol. . . . . THANKS!
Old Apr 17, 2007 | 09:39 PM
emilysrt's Avatar
emilysrt
ummm you will know when you red line 14psi when you look at your boost gauge LOL. you should be peaking at 18-19psi and can hold 14-15psi!! just dont go over board and turn it up high!
Old Apr 17, 2007 | 09:54 PM
silverblacksrt4's Avatar
silverblacksrt4
true dat!
Old Apr 17, 2007 | 11:50 PM
05SRTStage3's Avatar
05SRTStage3
I don't really know what u guys and girls are talking about. STOCK my 05 held 14 psi redline and never spiked.....unless I was going like 40 in fifth and floored it.....the boost sometimes went to 17 psi....but when the rpms got up high enough that it was like bogging down it went straight to 14 psi and HELD SOLID NEVER MOVED....but if you do want to boost it higher definately upgrade fuel and air....even a good tune....and wideband
Old Apr 18, 2007 | 03:38 AM
killerBsrt's Avatar
killerBsrt
kool thanks man so i shouldmove my psi up to18 psi and hold it @14 at redline on the stock fuel system and i should be alrite then rite?
Old Apr 18, 2007 | 04:14 AM
PSI Chick's Avatar
PSI Chick
stock fuel system is generally good for a 18psi spike holding 16. if you're messing with boost levels get a wideband, not every car is the same so just because one car can hold that doesn't mean that every one can.
Old Apr 18, 2007 | 11:23 AM
emilysrt's Avatar
emilysrt
then your boost gauge was f-up cause there is no way it was holding 14-15psi to redlind bone stock!! it would only do that with a wga on there!
Old Apr 18, 2007 | 11:25 AM
emilysrt's Avatar
emilysrt
are you kidding me?? i just told you that!!!!!!!!!!!!!!!!!! omg people!!!
