intercooler
Old Sep 7, 2004 | 02:34 PM
badsrt4's Avatar
badsrt4
Default intercooler
wuzz up guys, the other day i was checking out mdp.com and saw a couple of intercoolers (huge intercoolers) and i was wondering if anybody here has one in their srt's. i just want to know how hard its to install one and if its worth it. ( sorry if this issue has been posted before).
Old Sep 7, 2004 | 05:34 PM
SRTFOUR's Avatar
SRTFOUR
Default RE: intercooler
How much was the intercooler? try looking on ebay. It's always much cheaper. You can get a huge fmic for aout 400$ or maybe even less. Check it out. Those companies sell fmic for a lot more.
Old Sep 8, 2004 | 03:33 AM
Barneydriver's Avatar
Barneydriver
roach got an agp- ask him about it.
Old Sep 8, 2004 | 04:23 AM
millenniumdna's Avatar
millenniumdna
whats the purpose of a bigger Intercooler. Sorry if this a newb question Im guessing its bigger is cooler but im not certain
Old Sep 8, 2004 | 08:51 AM
71RoadRunner's Avatar
71RoadRunner
In general the larger the intercooler, the more surface space in which to lower the intake temperatures. It's just like with a radiator, the larger it is the cooler and more efficient it is. However there is a limit to how big, because it can only drop the temperature so much and sometimes a larger intercooler is simply a waste of money as it is no more effective that the smaller one. This is usually the case on the SRT-4's, the stock intercooler is large enough that you will need to be creating alot more horsepower, and in doing so more heat, to require a larger one to be at maximum performance again. Most of the larger intercoolers require modifications to get them to fit, most of which means permanently removing the front bumper itself for it to fit. If you want better intercooler performance, it is cheaper, easier and more benefitial to use an intercooler sprayer.
Old Sep 8, 2004 | 01:36 PM
badsrt4's Avatar
badsrt4
there's two ooptions both running about $700 to $800.
[IMG]local://upfiles/3555/16D4B28AF69F40F5986977CA3571E9B0.jpg[/IMG]
[IMG]local://upfiles/3555/05C1FD4EB4BE42E4BA1D572937D32065.jpg[/IMG]
Old Sep 8, 2004 | 01:38 PM
badsrt4's Avatar
badsrt4
found them in modernperformance.com but ill check on ebay... there's another one but ita about the same size, and its running for about $650 bucks
[IMG]local://upfiles/3555/19D4C696A2694012A698C3BF7190202D.jpg[/IMG]
Old Sep 8, 2004 | 04:00 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
You have to pay particular attention to the ground clearence as well. The stock SRT-4 intercooler already is fairly close to the ground, anything bigger might have some ground clearence issues.....
Old Sep 9, 2004 | 06:13 AM
Barneydriver
don't forget that bigger=more volume, which could mean less pressure, depending on the turbo's capabilites. also, there are more places for leaks, etc. With our stock turbo, i see no need to upgrade. i know roach did b/c he's planning on a bigger turbo later on- obviously that's a different story.
Old Sep 9, 2004 | 06:46 AM
71RoadRunner
That's right. I plan on sticking with the stock turbo myself, so the stock intercooler will do just fine for me.
