idle sensor
Old Apr 19, 2007 | 04:57 PM
silverblacksrt4's Avatar
silverblacksrt4
Default idle sensor
ok i think i def need a new idle sensor.. ok what its doing
1) while i'm not in a gear idle is reving up 1500, 2000,2500, even 3000k rpms...
2) also when idling sometimes the exhuast sounds like its coughing, sputtering..
so i think i do need a new idle sensor.. so how hard is it to change?? also where can i get one..
if u think its something else suggestions would be appreciated.. thanks!
Old Apr 19, 2007 | 06:59 PM
emilysrt's Avatar
emilysrt
Default RE: idle sensor
its cause your gay!
Old Apr 19, 2007 | 07:05 PM
flameredsrt's Avatar
flameredsrt
Sounds like the Tps.
Old Apr 19, 2007 | 08:33 PM
srt4babe's Avatar
srt4babe
I agree with Shane, my car was doing the same thing, TPS sensor was replaced by Dodge, under warranty.
Old Apr 19, 2007 | 08:44 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Yup, a TSB went out to Dodge dealers quite awhile ago. Don't let your dealer tell you otherwise...........
Dusty
Old Apr 19, 2007 | 08:57 PM
srt4babe's Avatar
srt4babe
Hey Dusty - Whats a TSB????
Old Apr 19, 2007 | 08:58 PM
flameredsrt
Tehnical service bulletin
Old Apr 20, 2007 | 01:43 AM
silverblacksrt4
what is a TSB?? its not technical service bulletin??
Old Apr 20, 2007 | 02:51 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
ORIGINAL: emilysrt
its cause your gay!
wow, that was helpful
its the TPS, had to have mine replaced as well under warranty. and yes... TSB is technical service bulletin
and incase anyone is wondering, TPS is the Throttle Positioning Sensor
Old Apr 20, 2007 | 09:41 AM
silverblacksrt4
well how do i fix it cuz i'm not on warranty!!!
