First Mods
Old Apr 23, 2007 | 12:37 PM
monstab757's Avatar
monstab757
Default RE: First Mods
Yeah spiking 17-18psi and then holding 15-16psi to redline. Our cars have the tendency to drop psi after 5K rpm cause of the weak stock wastegate actuator. Get a Stage 1 upgrade, AGP wastegate, and manual or electric boost controller and your there. I just put on the Stage 1 and im spiking 16-17psi and holding 13-14 till redline. Its a nice little upgrade. They only claim 10hp/10tq performance increase but you get alot of other cool features like improved throttle response, quicker turbo spool up, increase in boost, increased exhaust note, and boost hold during wot shifting.
Old Apr 23, 2007 | 01:53 PM
EricSRT4's Avatar
EricSRT4
I do have pictures of my 92lx and it is a complete drag car now. Yesterday was the first run for her this year and i pulled an 8.90 1/4mile. I have a small shot of nitrous i plan to spray to get me into 8.50s. I'll get some pictures and a video for you guys if interested.
I went with 500 because that is a good number, i came from rear wheel drive vehicles and the ford 302 block(ford stock 302 blocks crack at about 500 crank horsepower) I don't want to redo the block on the srt4 i want the most "safe" power i can make. If i fall short due to a block threshold or similar, ill survive that lol. I want it to be a daily car that i can drive with no worries of problems b/c as you can understand, driving around my mustang with 18psi of twin screw supercharger(i made 18psi by 2,100rpms) and a built block(dart block stroked and bored to 347, afr 205CC heads with 68cc chambers and 2.02 runners and 72# injectors with a 636 lift cam) becomes alittle expensive is something breaks and really hard to keep on the road, i can break traction on my nitto555r drag radials like i was driving on bald street tires. My goal is most reliable, fast and fun car i can have without worry.
Old Apr 23, 2007 | 02:10 PM
monstab757's Avatar
monstab757
In that case I would shoot for 400whp cause most people say that seems to be the threshold with stock internals.
Old Apr 23, 2007 | 02:19 PM
EricSRT4's Avatar
EricSRT4
400ish it is then. I don't want to replace the block by any means. I can get heads ported and polished no problem, change cams etc but takeing the block out is a pain. What kind of exhaust is still my concern, I don't like high pitch exhaust note, iv'e heard some mean sounding srt4s then iv'e heard some that make me think why did they even put that on there vehicle.
Old Apr 23, 2007 | 02:41 PM
monstab757's Avatar
monstab757
For exhaust you definitely wanna go 3" turbo back with a 3" 02 housing if you wanna achieve those numbers. Our exhaust systems are fairly simple. Basically after the turbine housing outlet you have the 02 housing then the downpipe and then the catback section. As far as what type, you have a lot of option. If you like the stock exhaust note with all the pops and gurgles then Id recommend a B&B turbo back or Exahust Depot turbo back. Both are 3" in diameter and can be equipped easily with a 3" 02 housing. If you want a more low que exhaust note then I've heard good things about the Perrin turbo back system.
Old Apr 23, 2007 | 03:07 PM
AirWolf's Avatar
AirWolf
ORIGINAL: EricSRT4
Still 400 hp for a daily driver is so-so and maybe you sould go with stage3 with or without toys to maybe get that hp. Maybe even 50 trim at most 60 would get you on the 500 hp side. I would also go with 3inch turbo back exhaust to go with whatever you get.
Old Apr 23, 2007 | 03:30 PM
MEandmySRT's Avatar
MEandmySRT
Most will say 3" but I'm happy with my Mopar CD and CB. I did make sure to upgrade the o2 housing to 3" though. Sounds pretty much like factory except just louder but not too loud.
Old Apr 23, 2007 | 05:06 PM
monstab757's Avatar
monstab757
Yeah but in his case he's not gonna want that stupid 2.25" bottle neck that most downpipes have. Just buy a full 3" turboback and you'll get better flow. Plus a lot of times you can buy a full turboback for cheaper than buying the dp and catback separate. Exhaust Depot has a full 3" turboback for $625 on special.
Old Apr 23, 2007 | 10:35 PM
valoagain!!!!'s Avatar
valoagain!!!!
OK 8 PEOPLE ALREADY SAID THAT HE NEEDS A EXHAUST !! DAAAAAAAAAAAAA OMG WE GET THE POINT !!!!!
Old Apr 23, 2007 | 10:37 PM
AirWolf's Avatar
AirWolf
Whatever you dont wanna start in with me you already have the whole srt4 section against you and Ive been on here alot longer than you . So quit your attitude with me alrighty!
