I was driving my car and the check engine light came on the code was p1188 which when I looked it up said tip sensor performance. What is it and what should I do about it. I just installed the old style AGP wga on saturday and I am boosting around 17 and holding it,could this be why cause the first day I put it on I got the overboost code and now this one.
the tip sensor is on the passenger side of the car, attached to the side. if you're throwing a code then the wire for it probably broke or popped off. just put it back on if that's the case. if not, then the sensor itself might be shot.
Yeah it came back on tonight so I have to replace the sensor I guess. On the other website there was someone saying I could just take the white line out completly and if that is true wouldn't that work?
