quick exhuast question
Old Apr 29, 2007 | 10:14 PM
MAssSrTdriven's Avatar
MAssSrTdriven
Default quick exhuast question
as you know im buying the perrin turbo back exhaust set up. will i need to buy the 02 sensor bung piece? or will i only need to run wideband sensor when upgrading turbo and fuel? will any codes trip with the new exhaust?
Old Apr 29, 2007 | 10:20 PM
jason vick's Avatar
jason vick
Default RE: quick exhuast question
Its never bad to run a wideband it just helps you monitor the afr's I dont know the exact setup of the perrin but if there is a cat delete it will usually have one preinstalled bung for the O2 as for the wideband when you order that it comes with its own bung in the kit for the extra sensor. Some cat delete pipes already have both with the option to close the secondary. If there is a cat there will be one for sure but usually not an additional it required drilling and welding of the second.
As for the codes.. you should be able to change you exhaust without any code issues that I am aware of.
Hope this helps!
Old Apr 29, 2007 | 10:34 PM
MAssSrTdriven
alright well, i am unsure as to weather or not perrin has the hole or not, and i guess ill have to call because it doesnt say on any sites ive checked.
Old Apr 29, 2007 | 10:51 PM
jason vick's Avatar
jason vick
It has one hole for sure I jsut found a pic the other will just have to be drilled and have the bung welded on for the wideband just google images for srt perrin exhaust
Old Apr 29, 2007 | 11:07 PM
MAssSrTdriven
so there is no wideband hole ill have to have one madE? could i just connect the wideband to the original hole and run my a/f meter from there?
Old Apr 29, 2007 | 11:20 PM
motorboy1's Avatar
motorboy1
Yea you could just put the widebandin the original hole but I think you will throw a code if you have stage 0 due to the pcm not reading o2 anymore. I have stage 1 and don't through any codes. My wideband o2 is in the bung at the cat. and I left the factory o2 sensor hooked up (if youunplug the sensor it will through a code)and just zip tied it out of the way.
Old Apr 29, 2007 | 11:22 PM
MAssSrTdriven
well i got the 05 factory stage 1 and i am going to buy the perrin tb but idk about throwing codes, and dont know if that exhaust has bung holes for wideband so i was seeing if i could just throw it in the bung hole provided in the exhaust and see if that would work?
Old Apr 29, 2007 | 11:23 PM
jason vick's Avatar
jason vick
I have the factory to the origional hole in the cat delete and the wideband to the hole that I added. I just followed the directions there is alot of ways to do it. the mod is easy just drill and weld. I paid someone to do it I think I paid 30 or so
Old Apr 29, 2007 | 11:35 PM
motorboy1's Avatar
motorboy1
It will work! just leave the factory sensor connected to the pcm and zip tie it out of the way. stage 1 no longer reads that o2 sensor but it will through a code if unpluged.install your widband sensor in that bung and your done! this is the way mine is done no codes thrown.
Old Apr 29, 2007 | 11:54 PM
MAssSrTdriven
so what do i do with the old o2 sensor if im leaving that plugged in? cut it off??? well i was told the 05s have the stage 1 kit in them along with the lsd, so if thats true i do have that if not then no stage kit but a 05.
