COLD AIR INTAKE....???
Do some research on the K&N.... From what i read on srtforums.com The gromet that holds the air sensor in place fell into the intake tube and was sucked up by the turbo causing some damage to the turbo. Advice was given to simply apply some super glue when installing this piece.
if that's true, that would suck (literally, i guess! [sm=smiley24.gif]).
the psi-fi is the company/brand name- see psifimotorsports.com - it looks like a quality piece. i'm still stymied. i need to just pick one and go for it.
The only way I could see the rubber peice being sucked into the turbo is if it was installed improperly or if there was a blockage causing an unusually high vacuum signal, like a plastic bag covering the air filter. I have gone full boost on more than a few occasions and mine is right where it belongs. Besides, every CAI I have seen has the same rubber gromet design and location, so if one has this problem they all should.
I went with the K & N Typhoon CAI, see:
[IMG]local://upfiles/193/885F9A4B9CA74A03B1F611774CAAD0C8.jpg[/IMG]
[IMG]local://upfiles/193/A7DA0695F2104A32841043D80CE995D7.jpg[/IMG]
