Noticed a difference..
I've noticed a difference in the time it takes to start my car--but it's only after it sits overnight-- and it's only the first start of the day when it happens. It just takes a couple more seconds to start than it used to. Is this a sign of something? If I had to guess I probably start it 4-5 times a day, and every other time it doesn't miss a beat. I daily commute with it, so I want to address anything that might put my baby in the garage [>:]
Yep so does mine I really started to notice it after i put msd wires on, at first it bothered me but since it still ran fineI didn't worry about it. Now it looks like maybe its a common thing so guess im even less worried.
it could be one of two problems....
1. summer gas. this time of year hard starts are common as the cars adjust to the change in gas. it usually goes away after a few weeks.
2. your fuel pump is failing.
Trending Topics
One suggestion may be to turn the key to the on position (without actually starting the engine) and wait till you here the fuel pump stop before you start it. That way the lines are 'charged' with gas....
ORIGINAL: aalva79
My car does that only in the morning as well it will cough a few times and then the rest of the day it will start normally, weiiird, thinkin about changing plugs again.
