track tips?
Old Sep 20, 2004 | 01:37 PM
Gump's Avatar
Gump
Default track tips?
hey later this week ill be taking my srt to the track for the first time. just wondering for you that frequent the track what should i know so i can make the srt look the best...
Old Sep 20, 2004 | 05:34 PM
roachnigga's Avatar
roachnigga
Default RE: track tips?
Launch off around 2000-2200 rpms
Shift @ 4000 to 2nd gear
Then go for broke... @ 5500-5700 all the way home
Good LUCK, Let us WAzzup
Peace
Old Sep 20, 2004 | 05:38 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Stay focused. Don't worry about everybody else, if this is your first time, they'll realize that. If they're running faster times, (and they will be) it's because they've had plenty of practice. That's what you need, and there's only one way to get it....
Old Sep 20, 2004 | 06:18 PM
posthondaremoval's Avatar
posthondaremoval
Silly question but just in case - You going to road course, autocross, drag...?
Old Sep 21, 2004 | 12:01 AM
Gump's Avatar
Gump
hey roach i find launching at anything 2000+ leaves me burning first... but the shifting at 4k in 1st is a good idea. and i usally shift at 5800 in other gears.
Old Sep 21, 2004 | 04:32 AM
Barneydriver's Avatar
Barneydriver
don't launch below 2k- roach is right- just feather the clutch a little off the line- i have about 20 runs at the track on mine now and it works pretty well (i haven't gotten to try w/ the motor mounts yet- i'm hoping i can run a higher rpm launch, but we're pretty much done for the season up here, and i'm going to be in the middle east until christmas- guess i'll have to wait until next spring!)
Old Sep 22, 2004 | 03:31 PM
Gump's Avatar
Gump
right on ill do a few dry runs on the way to the track.
Old Sep 23, 2004 | 04:29 AM
Barneydriver
keep us posted...
Old Sep 23, 2004 | 07:37 AM
roachnigga's Avatar
roachnigga
Glad i can help. Dont on launch in or around 2500rpm; you get the serious wheel hop.
Barney has more runs than i do... he's the back-up!
Let us know wassup
ORIGINAL: Gump
Old Sep 23, 2004 | 08:40 AM
glhs837's Avatar
glhs837
If you DO get wheelhop, back off the throttle some, DO NOT try to "drive through it". Thisd can lead to snapped axles (less likely on an 04), broken motor mounts, and in severe cases, dorked up oil pans. If you dont have radical hop, it's not an issue, so don't get freaked, if it starts, back off, then get back on it softer.
